1978 Ford F150 Custom
Old Sep 4, 2011 | 11:26 AM
TNLuke's Avatar
TNLuke
Can anyone tell me how to get the front of the drive shaft to disengag? We are replacing the rear U joint. We took the bolts out & bumped around it with a hammer. We put it in Neutral but it still seems locked in. WHAT AM I MISSING?
Also, it has a Motorcraft 2150 carbureator. I can't find a diagram of this carbuerator that matches mine. It has a small arm that is spring operated on the front side. The spring is broken & I can't even find anything to tell me what called or if I can replace the spring. The closest diagram I can find calls the button a fuel bowl vent value. I need the spring that goes on the arm to push that button. Any help is much appreciated!!!!!
hotrodjohn71
Dec 26, 2024 11:34 PM
TNLuke
Sep 6, 2011 01:12 PM
busted knuckle
Feb 4, 2006 08:22 PM
Bonkrr
Mar 27, 2004 04:47 PM
