2003 F250. On two separate occasions recently, I have had what sounds like the emergency flashers are on. Once with the key off, and yesterday, I turned the key on and heard it again. I noticed the Odometer light was flashing on and off. I did not notice the dash lights. Turned the key off and back on and all was well and engine started fine. Any ideas would be surely appreciated. Thanks Jim
update: Batteries at 12.75 and alternator at 14.8 volts.
Reason: update
Did it again tonight, switch off and back on, still there. Turn on lights and it quit.
Plug in volt meter reads 13.6 when running. Drove one mile and tried again and all is well.
I did notice that my digital odometer light is dimmer, with the lights on and brightness set all the way up.
Well It did it again today. I had the door open, sweeping it out, and I noticed my parking lights were flashing. Turned key on and dash lights were flashing. I haven't found the problem for sure, but I think it involves the after market door lock fob. When I push the lock button, it cause the same flashing lights. Just need to keep looking. FYI Jim
