Rusty Distributor
Rusty Distributor
Well, I think I found the cause of my stumble at idle...
I know I can get a distributor cap and rotor easy enough, but what can I do about the coil pickup tone ring? Can I get them somewhere without getting the whole distributor? Or should I just try to clean it up the best I can? I can't imagine the coil is getting a very good signal from that!
Pull the shutter wheel off, drop it in evaporust, clean it up & paint it or replace via junk yard. Don't know if it's available by just part.
Ignition, injection & fuel pump operation are all keyed of the signal from the PIP & all that crap does distort what the computer sees.
The PIP can only be removed by pressing gear off shaft. You can clean it with contact cleaner, stiff brush & compressed air.
This is what the pick up probably looks like:
The following users liked this post:
Yikes! I can get the whole distributor for that! lol. Thanks guys, I'll take it off and clean it up. I'm picking up a new cap and rotor today.
Someone mentioned painting it. That sounds good to keep it from rusting again, but would that effect the pick up? I know air gap is important, so I didn't know if the paint would interfere
Very true. I really don't want to mess with installing a distributor anyway! I just replaced the cap and rotor and my stumble at idle is completely gone. I didn't realize how rough it was running. It may be placebo, but it sure seems peppier too. I'll pull the shutter wheel out and clean it up eventually. Right now, I have other issues to take care of. Thanks for the info everyone!
Tonto Kowalski
09-09-2021 02:56 PM
NoHecks
22
07-19-2021 04:41 PM
TMI
07-15-2016 07:25 AM
