C4 problem
Old Sep 3, 2011 | 02:14 PM
jrlec1020's Avatar
jrlec1020
C4 problem
I have a mid 70's C4 trans in my 72 F100. When the trans is cold (first start of the day) I'll put it in gear and start to pull out of my driveway. The trans will slip and it won't go until I rev it two or three times. It will do this for approximately 2-5 mins after the first start of the day or if it has been sitting all day. It's not slipping out of gear. It almost feels like when your clutch is going out on a straight drive trans. After 2-5 minutes it will run good all day as long as it doesn't sit a long time to let the trans cool down all the way.
I've adjusted the linkage both ways. The fluid is clean and at a good level. I haven't checked the vacuum modulator. Could that be going bad? Maybe the filter screen is dirty? Maybe I'm not adjusting the linkage enough?
Any ideas?
Old Sep 3, 2011 | 02:19 PM
elgemcdlf's Avatar
elgemcdlf
Maybe it's time to replace it. When an automatic gets to this stage it's well on it's way to being finished. Schedule a rebuild/replace
Old Sep 3, 2011 | 11:05 PM
mblayton's Avatar
mblayton
Bands need adjustment, could be time for a rebuild.
76-F100
Jun 14, 2013 10:08 PM
Talyn
Sep 30, 2012 11:15 AM
jrlec1020
Sep 3, 2011 10:34 PM
bomberboat
Oct 27, 2008 01:45 PM
danimal
Feb 7, 2006 11:33 AM
