Wiring color help PLEASE.
Old Sep 2, 2011 | 09:45 PM
bigcheez's Avatar
bigcheez
Hi Folks, I am trying to install a plasmaglow scanning taillight bar on a 2010 f150 and having a hard time. I need to isolate the turn signal wires to connect the taillight bar. Can anyone tell me what color the left and right turn signal wires are either at the column or behind the kick panel in the drivers foot well. Thanks.
Old Sep 2, 2011 | 11:40 PM
Jus2shy's Avatar
Jus2shy
Do you have the trailer pins that you can tap? That'd probably be the best place to tap power for your light bar. Also the easiest to test and determine which color goes to which direction...
Old Sep 3, 2011 | 04:57 AM
shotgunz's Avatar
shotgunz
Trailer Wiring Diagrams | etrailer.com
Old Sep 3, 2011 | 07:24 AM
bigcheez's Avatar
bigcheez
I have tried using the wiring at the 7 pin/4 pin. The problem seems to be that there is no "turn signal only" bulb (light). I had a lightbar on before and had spliced it into the trailer harness for a clean look but this scanning light bar requires seperate connections for Left signal, Right Signal, Running lights, Brake lights, Reverse lights, 12V power, and Ground. My thought was that if I tapped into the signal only wires at the column or better at behind the drivers kick panel in the footwell, I could get this thing working.
MIKEDEL
20
Aug 6, 2020 08:01 AM
ForeverFixing
All Things Towing
Apr 22, 2019 08:16 PM
CDavis26
Jun 22, 2015 12:15 PM
Nicktitan
15
Apr 8, 2015 05:48 PM
Richard in Tacoma
Electrical Systems/Wiring
Mar 25, 2002 05:28 PM
