problem starting when cold
Old Sep 2, 2011 | 09:24 PM
bjones2305's Avatar
bjones2305
I have a 1976 Ford F250 needs to start everytime needed, its used for emergency uses. Weather is getting colder here now, and engine starts when its warm, but not easily when cold.
Wondering since its older if plugging in a block heater might work? We do that for older fire engines, wondering if it might work in this case??
Old Sep 2, 2011 | 09:30 PM
CharlsChainCharlson's Avatar
CharlsChainCharlson
Recently after a carb rebuild my truck starts very well in the cold. Might want to try that out if it's been a while for your truck. Hey a bit of a tune up goes a long way.
Old Sep 2, 2011 | 09:48 PM
montana_highboy's Avatar
montana_highboy
Is your choke working? it's probably electric unless someone converted it to manual, if electric it should be almost completely closed when engine is cold and slowly open as engine heats up, if it's manual then obviously you decide when to open/close the choke. (using a block heater certainly doesn't hurt in cold temps).
Old Sep 2, 2011 | 09:58 PM
4x4 Bart's Avatar
4x4 Bart
Remove your choke housing and spray carb cleaner inside until it's good and clean. Everything should move freely. Be careful to make sure the metal hook on the coil and is looped around the choke lever.
82_F100_300Six
23
Jan 22, 2018 09:46 AM
boboh1
Apr 21, 2013 08:45 PM
c.wathen
Jun 20, 2009 06:50 PM
78ford351m
26
Dec 17, 2008 04:53 PM
nightcrawlermc
Bronco II
May 17, 2003 10:15 PM
