460 pulley HELP
Old Aug 31, 2011 | 09:08 PM
jordanbennett's Avatar
jordanbennett
460 pulley HELP
hey guys, i managed to drop my 1970 460 into my 78 f250 1 ton'd
yesterday and im running into some problems with my ps pump hitting my steering box. and also my brackets for alternator are not working.
does anyone have any pictures of the front of there 460 swap, i really need some info on the pulleys maybe there is a certain style that will work?
heres what the motor looks like.
any pictures or help would be greatly appreciated
Old Aug 31, 2011 | 10:37 PM
co425's Avatar
co425
On mine I ended up doing a saginaw pump conversion with a bracket out of a van with a 460. . I used an L&L bracket for the alternator and took a 1/4 out of the spacer and it all lines up fine. If you need a pick of the alternator it will have to wait till morning it's dark out here all ready. Here's the best pic I have.
Old Aug 31, 2011 | 10:53 PM
jordanbennett
thank you thank you thank you!
this is helping alot
yeah more photos would be great man i look forward to it
do the brackets from the van all bolt on, any fabbing needed?
Old Aug 31, 2011 | 11:09 PM
brian1080's Avatar
brian1080
to somewhat threadjack, what are people doing that also want to keep a/c? Looks like your way puts the ps pump right where the ac pump is.
Old Aug 31, 2011 | 11:16 PM
jordanbennett
no worries man, no, no need for ac, strickly mud truck
Old Aug 31, 2011 | 11:50 PM
mark a.'s Avatar
mark a.
I used this style power steering bracket. Redrilled the top hole & made a small bracket to move the bottom bolt up and tilted it up some. Had to cut a chunk out of the end with the draw stud and weld it back in so it would move down farther in the slots so it would tighten up. The pump is a 351M-400 Sag conversion pump with the long shaft & a different can from a junk yard pump. I made the alt bracket from some of the 400's bracket & some fabrication. Lot of work but it can be done without buying the expensive L&L brackets.
Old Sep 1, 2011 | 12:02 AM
co425's Avatar
co425
Yes the van brackets just bolt right on. No messing with it required. The worst thing I had to do was get a hose made at the hydraulic shop. No biggie it's standard stuff if you stick with the earlier Saginaw that does not have an o-ring fitting on the pump.
Old Sep 1, 2011 | 12:03 AM
mark a.'s Avatar
mark a.
Old Sep 1, 2011 | 12:56 AM
jordanbennett
okay perfect, i will start the hunt, would you happen to know when they went to the oring style so i dont get the wrong one?
thanks guys for the replies, its helping alot. im getting so eager to get this thing running been sitting for too long!
Old Sep 1, 2011 | 10:37 AM
co425's Avatar
co425
If the back resivour bolts are metric it's o ring for sure. There is two and sometimes one bolt. Rebuilt pumps are pretty cheap. The brackets will all work as long as it's a canned ham style pump. This is what came with a Saginaw. I know there are more but this is my list. Also if you are going for a pump be mindful of the cars with hydro boost. They have two returns in the can. Also if you are going to buy a rebuilt make sure you find a Saginaw at the yard and snag the two resiviour bolts. A rebuilt pump won't come with them.
Saginaw P/S pump:
1973: Thunderbird/Continental Mark IV.
1974: LTD/Mercury Marquis 460 & Thunderbird/Continental Mark IV.
1975: LTD/Mercury Marquis 400; 460-without A/C / Thunderbird/Continental Mark IV.*
1976: LTD/Mercury Marquis 351/400/460 with or without Hydro-Boost / Thunderbird/Continental Mark IV.
1977/78: LTD/Mercury Marquis 351/400/460 with or without Hydro-Boost / Continental Mark V 400/460.
1979 Continental Mark V 400.
1973/79 Lincoln Town Car.
1977 Econoline from serial number O40,001 / 1978/91 Econoline.
LTD includes Country Squire/Country Sedan / Mercury Marquis includes Colony Park.
1975 to 78 Econlines
Old Sep 1, 2011 | 10:50 AM
co425's Avatar
co425
Here's that alternator pic.
Old Sep 1, 2011 | 10:57 AM
psquare7575's Avatar
psquare7575
Even if it has an Oring, it can be done with off the shelf parts from Summit/Jegs. I made up a hose using fittings and Powerflex hose from Russell.
Old Sep 1, 2011 | 12:03 PM
jordanbennett
cant say thank you enough man! this helps greatly!
i found a 87 and 75 e350 with 460s at my local picker.
im going to drive out and see if i have anyluck
Old Sep 1, 2011 | 12:29 PM
mark a.'s Avatar
mark a.
Are these the L&L brackets ? If they are what did they end up costing ? I haven't had ant problem with my cobbled set up but these look so nice !
Old Sep 1, 2011 | 12:31 PM
jordanbennett
heres a link
http://www.landlproducts.com/list.as...cID=6&scID=124
