1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
very strange problem with scan tool
Old 09-02-2011, 05:49 PM
huntdiamondjim's Avatar
huntdiamondjim
huntdiamondjim is offline
4wd High
hi guys was wondering if anyone else has had the a problem with reading their codes. i plug my scanner in and keep getting message that says tool not connected. scanner diffently works as i have other fords i checked it on. is there a fuse on something i should be looking for? ive tryed to search this forum but haven't seen this problem anywhere. i guess that means i'm special. by the way it is a 99 f350 with 225,000. so it has a little wearbut what a great truck it has been. thanks jim
Old 09-02-2011, 06:17 PM
jc8825's Avatar
jc8825
jc8825 is offline
There is a fuse for the OBD port, but I don't know which one.
Old 09-02-2011, 06:23 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
Check your cigarette lighter. Its on the same fuse. If it doesnt work, then the fuse it blown. That happened to me.
Old 09-02-2011, 06:29 PM
ToMang07's Avatar
ToMang07
ToMang07 is online now
Yuppers...
Fuse Finding Frenzy Fiasco!
Old 09-02-2011, 06:34 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
On a 1999 it should be fuse 3 under the dash. A 20A fuse.
Old 09-02-2011, 08:31 PM
huntdiamondjim
4wd High
thank you trey and others
thanks so much for info. that was it!! read codes and believe it or not it is cyclinder 1 misfire. my lucky day!! thanks again jim
Old 09-02-2011, 10:29 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
Glad you got it fixed
cm6pack
04-24-2013 10:42 AM
lowbed dud
11-21-2012 04:35 PM
tomb391
05-24-2009 11:13 PM
billcox
1997 - 2003 F150
02-20-2006 06:20 AM
taltonallen
09-03-2004 12:39 PM
Quick Reply: very strange problem with scan tool
