Sponsored by: Real Truck
When do you replace your rotors?
Old Sep 1, 2011 | 05:57 PM
smlford's Avatar
smlford
I have 91K on my F-350 below and am on my second set of pads (Hawk SD).
It looks like i will have to do another brake job in the next 5K or so and I am wondering how long the rotors are suppose to last. Is there a minimum rotor thickness then you have to replace them? On my race car they allow a 2mm decrease from new before they reccomend replacing them.
Anyone know of a good source?
Old Sep 1, 2011 | 06:01 PM
dkf's Avatar
dkf
The minimum thickness (letters) measurement is cast into the rotor.
Old Sep 1, 2011 | 06:15 PM
sandmanf250's Avatar
sandmanf250
i'm at 207.000 thousand now and am about to replace them now,although they are free of pulsing.i think they may be getting rusty in the cooling fin area.
Old Sep 1, 2011 | 06:25 PM
1973Ford2004's Avatar
1973Ford2004
117,945.8 miles never replaced or turned rotors, did replace pads at about 85,000. My fins have been rusty for about 5 years, no warping, no pulsing, knock on wood I have a 2004
Old Sep 1, 2011 | 08:14 PM
senix's Avatar
senix
typically never replace unless grooves or warped or you reach the min thickness.
If you take it in for a brake job at a repair place they will advise to always turn the rotors...but then you will almost always be out of spec.
Old Sep 2, 2011 | 11:21 AM
smlford's Avatar
smlford
[quote=senix;10764723]typically never replace unless grooves or warped or you reach the min thickness....[/quote]
That's what I'm trying to find out per Ford specs.
Old Sep 2, 2011 | 11:26 AM
Blue Jay's Avatar
Blue Jay
I just replace them if they are warped, cracked or if they need turned down i just replace them instead.
texastech_diesel's Avatar
texastech_diesel
Token Redneck
The min thickness should be stamped on the backside of the rotor, pull and examine.
Front Disc Brake Rotor Thickness 1.5 in
Rotor Minimum Thickness 1.417 in
Note: Minimum rotor thickness is molded into the disc brake rotor
Rotor Maximum Runout
SRW 4x2 0.0020 in
DRW 4x2 0.0028 in
SRW/DRW 4x4 0.0015 in
Rear Disc Brake Rotor Thickness 1.181 in
Rotor Minimum Thickness 1.102 in
Rotor Maximum Runout 0.0015 in
Borrowed from Alldata via another diesel place, was for an 05 I believe.
Old Sep 2, 2011 | 12:23 PM
cpickner's Avatar
cpickner
Do you guys have new rotors turned before you install them. I worked for a shop and they always did. Something about scuffing the surface.
Old Sep 2, 2011 | 01:51 PM
SteveH-CO's Avatar
SteveH-CO
New rotors should be ready to install. They should be thoroughly cleaned with brake cleaner to remove any anti-rust compound residue on them. Rotors should not be shiny, so if they had a mirror surface, then they should be turned or scuffed with 60 grit abrasive.
Old Sep 2, 2011 | 06:20 PM
sand_fiend's Avatar
sand_fiend
I bought my truck used. I got a bad peddle pulse because of warped rotors.
I had them surfaced and it came back in less than 5K. worse.
The inside was built up rust and flaky.
I guess the rust in the cooling fin's was not letting them cool down enough during city driving.
I bought new rotors and Just put them on. The brakes felt a little soft and the truck pulled side to side a little while applying the brakes. after about 3 or 4 times of getting them hot and let cool down, it was gone and everything is good..
I did not by the high dollar rotors..
I think i payed like $50 each..
Old Sep 2, 2011 | 08:12 PM
Surge08's Avatar
Surge08
I believe when they are warped or grinding then replace. I don't believe in turning them as the more metal you take off the more the piston on the caliper has to travel to apply the brakes and are more subject to warp due to the decrease of material on the rotor.
Old Sep 2, 2011 | 08:28 PM
hotroddsl's Avatar
hotroddsl
I replace at every brake job with the cost of rotors it's just abought a wash between the cost of the machining and the hassle of getting the rotors to the machine shop it's easier for me to just put on new.
Jim...& fat Monty
Old Sep 2, 2011 | 09:24 PM
3cv's Avatar
3cv
When do I replace my rotors? Tomorrow...
Old Sep 2, 2011 | 09:59 PM
92f150I6's Avatar
92f150I6
dang, you have to do bearings too.
