Oil Pump??
Old Sep 2, 2011 | 04:01 PM
91 Dually's Avatar
91 Dually
Oil Pump??
OK, So I've finally got my engine back together. Trying to get started. Had her torn down to the block. Had heads rebuilt. Installed new stage one injectors. T500 HPOP.... I fill the HPOP reservoir, crank engine, it tries to start, but just won't take off... remove fill plug in HPOP reservoir... Oil level low... I guess this means the HPOP is working, but the oil pump is not refilling reservoir?
Old Sep 2, 2011 | 04:08 PM
427 fordman's Avatar
427 fordman
If you did a lot of cranking, it can cause it to drain down, especially on a fresh motor I would think. I say fill it up and give it another try.
Old Sep 2, 2011 | 04:21 PM
91 Dually's Avatar
91 Dually
Have done that probably 4 times already..... should I see oil pressure guage rise while cranking engine, or does it have to run to do that?
Old Sep 2, 2011 | 04:38 PM
King7765's Avatar
King7765
It's broken. Sorry.
Just go head and send it north to me. I'll take the problem off your hands...
Old Sep 2, 2011 | 06:20 PM
91 Dually's Avatar
91 Dually
Hey!! That wasn't nice
Old Sep 2, 2011 | 06:47 PM
427 fordman
I don't think you'll see the gauge move til it starts. If you've filled it 4 times already, seems like your lpop isn't feeding the hpop for some reason like you mentioned. Gonna have to get some of the guys that have actually been inside these motors on to help you out more. And I'd much rather you sent that truck my way since I answered you first!
Old Sep 2, 2011 | 07:42 PM
bad12jr's Avatar
bad12jr
It will drain it. Took a little bit to get mine going after the front cover replacement. Remember the hp oil system has to fill as well as the front cover, oil galleries, cooler and bleed out the air. Just keep refilling until it starts oil psi will move and bounce. That means that your getting some pressure and air.
Old Sep 2, 2011 | 10:33 PM
Talyn's Avatar
Talyn
you wont see the gauge move on the dash. Thats the pressure the LPOP is pushing to the resivior. So until the pressure is built there, you wont see it.
No oil in the rails = pretends it wants to run.
Just keep at it till you work the air out. its a bugger to get em started after pulling injectors.
justinlb917
57
Jan 13, 2016 08:50 AM
bobbyrjw
Feb 6, 2010 06:09 AM
GeoffNJ
Oct 20, 2007 11:13 PM
mybigredford
Aug 29, 2007 06:59 PM
Jerry ranger9
Oil & Lubrication
Apr 21, 2004 10:02 PM
