Problem starting
Old Sep 1, 2011 | 03:40 PM
bjones2305's Avatar
bjones2305
Problem starting
Im am a noob at this so just a little patience...just bought a 1976 ford f250. Been running ok, ran out of fuel, put in more then re-started it. Ran for a minute then died. Continues to do so, or just wont start???
Any help
Old Sep 1, 2011 | 03:44 PM
co425's Avatar
co425
Probably sucked up some sediment from the fuel tank. Time to check and see if you have a bunch of crud in your tank. You may need to clean the in tank filter sock, blow out the lines and replace the fuel filter.
Old Sep 1, 2011 | 03:59 PM
jsutton's Avatar
jsutton
Yea, it probably sucked up some trash. I have no idea what carb you have, but if you have a stock 2 barrel on there it wouldn't hurt to replace the fuel filter that screws into the front it. You can also get you a clear inline fuel filter so you can see what the gas looks like when it's flowing.
Old Sep 1, 2011 | 04:02 PM
bjones2305's Avatar
bjones2305
just replaced the fuel filter a few days before this happened and also placed a clear inline filter on it...
Old Sep 1, 2011 | 04:07 PM
montana_highboy's Avatar
montana_highboy
What part of Montana are you in?
Old Sep 1, 2011 | 04:09 PM
bjones2305's Avatar
bjones2305
Libby and You
Old Sep 1, 2011 | 04:12 PM
jsutton's Avatar
jsutton
So is the clear one all clogged up now or is it still clear? Does it have gas in it to show that the fuel pump is pumping gas up to the carb? Take the one off the carb and try to blow through it and see how much air gets through.
Sorry if those seem like stupid questions, I'm just thinking about process of elimination for the problem.
Old Sep 1, 2011 | 04:13 PM
barbie85033's Avatar
barbie85033
My problem is:.... someone chiseled and grinded and tore up the starter switch.. i basically had to drilll the old lock out.....but what my question is i put the new cylindar switch in but when i turn the key nothing happens .... i had this prob once before when i diconnected battery.... but dont know what i did to fix it...-please help
Barbie
Old Sep 1, 2011 | 04:25 PM
montana_highboy
Originally Posted by bjones2305
Libby and You
Libby as well, you wouldn't happen to be the guy over near Flower Creek that just bought a baby blue highboy are you?
Old Sep 1, 2011 | 04:59 PM
bjones2305's Avatar
bjones2305
yep...hahahah
Old Sep 1, 2011 | 05:00 PM
bjones2305's Avatar
bjones2305
worked like a charm thanks guys
Old Sep 1, 2011 | 05:03 PM
montana_highboy
yep...hahahah
I figured i'd run into you on here sooner or later.
Good to hear you got it running again.
Old Sep 1, 2011 | 06:29 PM
montana_highboy
Here's a few 73-79 parts over in Marion if you need anything you don't already have...
1973-79 pickup parts/tires & wheels
jhinalabama
2009 - 2014 F150
May 18, 2018 12:37 AM
MartyMiller
Escape & Escape Hybrid
Oct 7, 2008 07:47 AM
SexyMF150
Apr 4, 2004 08:31 PM
Bronco86
Jan 2, 2004 01:45 PM
