6.7 Engine Failure
Old Aug 31, 2011 | 08:29 PM
sgrol's Avatar
sgrol
6.7 Engine Failure
Ok, this may be boggus info but my son, who drives a Duramax, was talking to a Dodge Diesel tech the other day and the tech said the new Ford 6.7s were having problems with piston sleeves detaching from the block and stretching the head bolts causing the head gaskets to blow. I have searched the forum and found no evidence of this but thought I would throw this out to see if there is any truth to this.
Old Aug 31, 2011 | 08:35 PM
Rick Cargo's Avatar
Rick Cargo
I've had my truck over a year and have had the opportunity to talk to the diesel mechanic at my dealer a few times and he told me that the only wrenching that he has done in that time is oil changes and services.
Old Aug 31, 2011 | 08:36 PM
Onus's Avatar
Onus
I call bs. The piston sleeves wouldn't come out anyway they are cast with the block. Only engines i've heard that happen on the 7.3idi and 6.9idi that have been sleeved without putting a lip to stop the sleeve from dropping into the block.
Old Aug 31, 2011 | 08:43 PM
powerstroke72's Avatar
powerstroke72
That's the first I've heard about it. Of course, consider the fact that the source was a Dodge / Ram / Fiat Tech.
Old Aug 31, 2011 | 08:55 PM
dschuffert's Avatar
dschuffert
I think this is just a bad rumor. Or guys trying to one-up each other. There is no evidence of this nor can I find any references to this type of issue.
Old Aug 31, 2011 | 08:59 PM
sgrol's Avatar
sgrol
Good to know. My son is going to ask him where he got his info since it does seem to be BS. Kind of scared me cause I'm looking at the 6.7 as a replacement if mine ever fails.
Old Aug 31, 2011 | 09:03 PM
FishOnOne's Avatar
FishOnOne
I not aware of the 6.7 psd having cylinder sleeves!
Old Aug 31, 2011 | 09:24 PM
sgrol's Avatar
sgrol
I just happen to be in Katy tonight. Don't know if they have liners or not. If not, then the guy has a lot of explaining.
Old Aug 31, 2011 | 09:39 PM
cummins cowboy's Avatar
cummins cowboy
the only problem with engines I have heard of is a few bad cams back about a year ago, the batch was traced down and fixed. seriously I think ford can spike the football with the 6.7 none of our members here have had an issue that I know of with the engine. the 6.7 might just be the most reliable initial release ever for a pickup diesel engine and that includes the cummins engines that are legendary.
Old Aug 31, 2011 | 09:54 PM
Dim Sum's Avatar
Dim Sum
Other than Cab and Chassis trucks, I've seen only 1 engine failure of the 6.7 to date and he had 180 miles on the truck.
Old Aug 31, 2011 | 10:16 PM
Tom's Avatar
Tom
Yeah...I think we can safely say this is bogus info. The 6.7L has been very reliable for the ~15 months it's been released to the public. Catastrophic failures have happened but they seem to be very rare. A couple instances of chassis/cab trucks dropping valves and one cracked block are all I can remember.
Old Aug 31, 2011 | 10:42 PM
Rich1961's Avatar
Rich1961
The Utility I work for has a fleet of about 400 6.7's, so far company wide we've lost 15 engines, 5 in my area alone. All were due to head issues, valves breaking and hitting the pistons, destroying the engine. Needless to say, Ford is working on a fix. The engines with the issues are VIN # specific (Mine is one of them) and I was told by our Fleet Dept. that it looks like the heads may have to be replaced on 267 of them.
Rich
Old Aug 31, 2011 | 11:09 PM
Dim Sum's Avatar
Dim Sum
That is interesting. I can't wait to see that TSB....or recall as it better be a recall in the VIN range is wide spread.
Old Sep 1, 2011 | 01:48 AM
kper05's Avatar
kper05
I don't know of a single pickup 6.7L that has had engine failures but there is chatter around the internet about a few cab & chassis 6.7L engine's having parts fail.
Not sure why those have an issue with less power.
Old Sep 1, 2011 | 02:24 AM
bookem15's Avatar
bookem15
Go back and let them know they should check some info before they try to fabricate a lie like that. These engines do not have sleeves. Sounds like they are just being stupid
