1973 360 bogs when accelerating
Old Aug 31, 2011 | 04:06 PM
schmidtty_79's Avatar
schmidtty_79
I've searched hi and low and can't find this addressed in any other post so sorry if I'm beating a dead horse.
I have a freshly rebuilt 360 all stock with the acception of an Edelbrock Performer manifold and Edelbrock Performer 1406 carb. I've just finished getting everything together and running. The truck starts and idles fine, but doesn't want to accelerate when in gear. It bogs and will die if I continue to give it gas. That is with the timing set to factory specs 3 degrees. Since I went from a 2 barrel carb to a 4 I have tried bumping up the timing to about 13 degrees. I can now accelerate and go down the road, but it still tries to bog and definitly doesn't like hills. I am also still using the factory ignition system with the points. Obviously I know just enough to get myself into trouble, but don't know where to go from here. Do I need to advance the timing more? My next step is going to check out the accelerator pump. Any tuning tips?
Old Sep 1, 2011 | 10:05 AM
rustywheel68's Avatar
rustywheel68
i don't think i'd advance the initial timing any further- that's about as far as you can go for a stock setup.
i'm not terribly familiar with the Edelbrock carbs, but if this were an Autolite, then i'd be saying you should checking out the accelerator pump. for some carbs, at least- there are different size diaphragms, and you can also adjust the pump arm.
when you step on it, will it start to die and then pick back up, or does it just completely shut down?
Old Sep 2, 2011 | 08:39 AM
schmidtty_79
It will completely shut down. It's not like a hesitation and then it will go.
Yeah, I'm going to move on to the accelerator pump tomorrow. Your right the pump arm is adjustable.
73 ford guy
Oct 1, 2012 10:15 AM
Mav06
33
Mar 1, 2007 11:07 AM
mudslingur
Feb 14, 2007 09:08 PM
the tank
Feb 7, 2005 03:34 PM
Derrick1972
Feb 1, 2004 06:43 PM
