Evaporative system error and e-test
Old Aug 31, 2011 | 11:13 AM
spinnr's Avatar
spinnr
Hi
I had an evaporative system error code today on my 1996 ford explorer(sorry, can't remember the code #) and have an e-test to do within a week. Can you pass the e-test if this error happens to come back or is it likely to fail anyway, even if it doesn't come back. I've read it could be as simple as a gas cap or else a small leak somewhere but was hoping not too need to do anything before the e-test if possible.
Also- what would be the worst case cost to repair something like this, if possible to suggest an amount?
Thank you
Old Aug 31, 2011 | 09:03 PM
aquanaut20's Avatar
aquanaut20
Very possible it was related to the gas cap/dirty gasket....
If you erased the code by means of a code reader, the ready monitors were also reset to OFF/incomplete. They will fail the vehicle if the RM have not cleared their drive cycle... Philip
Old Sep 1, 2011 | 06:23 AM
projectSHO89's Avatar
projectSHO89
Check with the bureaucracy in charge of your emissions testing and see how many "incomplete" monitors you're permitted for your vehicle. Most jurisdictions permit one or two "not-ready" indicators and will still pass you.
Old Sep 1, 2011 | 08:13 AM
KhanTyranitar's Avatar
KhanTyranitar
most evap codes are either due to a leak on one of the evap hoses, which you can trace from the intake to the canister, and from the canister back to the fuel tank, or the gas cap, which is easy enough to replace, and most etests can narrow the gas cap down, a lot of jurisdictions are required to test the cap. I would not reset the system quite yet.
Ford'05HG
1983 - 2012 Ranger & B-Series
Oct 26, 2016 09:10 AM
tseekins
Apr 7, 2015 02:30 PM
bc56845
Escape & Escape Hybrid
Mar 7, 2007 09:10 AM
4.0 Beast
Sep 25, 2006 11:13 PM
jstang95
1997 - 2003 F150
Feb 21, 2005 09:24 PM
