More C6 trans shifting issues
Old Aug 31, 2011 | 09:09 AM
irwink3's Avatar
irwink3
Hey all
I recently inherited my grandfathers '79 F250 w/ 460 and C6. Trucks been sitting for years, and after a quick tune-up, I started putting on some miles. It has some sort of shift kit, and after fixing the many vacuum leaks, it doesn't seem to be shifting right.
I've tried adjusting the modulator, but I'm not noticing any difference. It currently shifts 1-2 at 25 - 30mph and 2-3 at 55-60mph. Not matter what I do, I can't seem to get it to change. Any thoughts?? Thanks!
Old Aug 31, 2011 | 12:05 PM
jmikeyj4's Avatar
jmikeyj4
on c6's i believe there is a belt inside which usually wear out....
Old Aug 31, 2011 | 09:39 PM
RWENUTS's Avatar
RWENUTS
TRy turning the screw in the modulator out all the way. See how it shifts then.
Old Aug 31, 2011 | 11:05 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Sounds like the modulator isn't receiving a vacuum signal or at least much of one. How good is the line from the manifold to the modulator?
Maybe the pin behind the modulator is possibly missing, hence why the adjustment has no effect.
Josh
dustyroad
20
May 8, 2019 07:36 PM
camcol19
Nov 16, 2014 07:35 PM
maribou912
Nov 29, 2011 08:11 PM
JoeF150
Feb 27, 2003 02:56 PM
tbolt 460
Jun 7, 2001 11:29 PM
