C6 servo
Old May 31, 2001 | 07:34 PM
tbolt 460's Avatar
tbolt 460
C6 servo
I have a C6 with a "H" servo in it.Can a lesser tension spring,(or remove it)be installed to make it shift into 2nd harder?It has a B&M transpak in it and still does'nt hit 2nd hard enough.It shifts into 3rd real good.How about enlargening the oil hole in the servo cover,would that help.I removed the spring on a 904 AMC trans once and shifted into 2nd real nice.Can the same be done to the C6 and maybe even the C4.HELP!!
Old Jun 7, 2001 | 01:38 PM
mattb's Avatar
mattb
C6 servo
what type of vacuum modulator do you have? is it the adjustable one? if so you can play around with that to adjust how hard and at what rpm it shifts in 2nd. turn it in to harshen the shift, turn it out to soften it. the adjusting screw would be located inside of the vacuum fitting, it is a flathead screw.
mattb
Old Jun 7, 2001 | 11:29 PM
69cyclone's Avatar
69cyclone
C6 servo
danimal1004
Dec 21, 2014 08:08 PM
dmolaver
Sep 4, 2014 12:43 PM
1979F350/460
Sep 5, 2013 11:15 AM
bruno2
Oct 24, 2011 01:28 PM
timothy47129
Jul 19, 2006 11:19 AM
