diesel issue!!!!!
Old Sep 1, 2011 | 11:54 AM
Snuggyworm's Avatar
Snuggyworm
have ur egr valve, egr cooler and oil cooler checked. tat was some of the many symptoms which u described tat happened to me b4.
also, u might consider changing ur dummy pipes / standpipes n changing ur crossover pipe wif the updated stc fitting. just a thought.
good luck!
Old Sep 2, 2011 | 07:14 AM
strokin one's Avatar
strokin one
thanks
it has a sinister egr delete kit, just had brand new oil cooler installed when they had the heads off!! all the other stuff has been done also within the last 6 months!! puzzled!!
Old Sep 2, 2011 | 02:16 PM
A J Rana's Avatar
A J Rana
Exclamation Weird starting first strat of the day.
Help I got one for you F 350 2007 6.0 starts fine, then put it reverse backs up , but when I shift it to drive she stalls. Restarts no problem ...does this 4 or five times and stalls when I put it in gear OR even turn the steering wheel. Then it starts goes into gear fine and runs all day no problem.
Next morning repeat of the problem????
Any ideas and or solutions to a similar problem mucho aprreciated.
A J
Old Sep 2, 2011 | 04:20 PM
strokin one
hello
i had a simmillar issue on my 05, it finally ended up in limp mode and had to unplug icp sensor to get home replaced it and it was fine!! on a fuel note fuel filters need to be changed pretty regular frame side and motor!! does your fuel pump sound like its straining before you start it??
Old Sep 3, 2011 | 06:41 PM
A J Rana's Avatar
A J Rana
I change the fule filters every 6k... Iknow I need to based on the crap they are selling us for fuel. ICP sensor? is that the same as the cam sensor? I am having both the cam and crank sensors replaced.....that should be the fix based on the service bulletins I have read. The dealer was trying me to buy the engine harness...saying it had " high resistance" Im no electrician but if it had high resistance cold ? then why does the truck run fine after heating up?
Explain the ICP please thanks for the come back.
A J
Old Sep 4, 2011 | 07:34 PM
Snuggyworm's Avatar
Snuggyworm
@ a j rana, icp sensor is not the same as cam sensor.
Stoneburg86
Dec 6, 2016 08:52 PM
mechelement
Apr 20, 2015 11:26 PM
bossgobbler
15
May 5, 2011 05:04 PM
Salty Aggie 93
Nov 26, 2010 07:43 PM
jelzy
Apr 25, 2010 07:03 AM
