1978 - 1996 Big Bronco
Eletric 4x4 switch
Old Aug 30, 2011 | 09:12 PM
krave's Avatar
krave
Eletric 4x4 switch
I have a 92 bronco that has the eletric 4x4 and low gear switch on the dash.But I have never needed it or used it in the 8-9 years I have had the truck tried it yesterday and it does not work and am curious if this a commen problem? what are if any solutions and how much does a new switch cost if I need to go that rought.
Any help thoughts and or advice would be great..
Thanks Gary
Old Aug 30, 2011 | 09:15 PM
AzPete's Avatar
AzPete
Do you get anything different when you select 4x4 high? Indicator light on? Any clicking of relays?
Always good to use them for 5-10 miles a month plus it is fun...
Old Aug 30, 2011 | 09:37 PM
krave's Avatar
krave
No I get no lights the truck doesn't change at all its like the switch isnt plugged in the back.but that seems to easy but when I get in to it it will be the first thing I check.
Thanks
Old Aug 30, 2011 | 10:02 PM
AzPete's Avatar
AzPete
Have you checked for fuses in the truck plus under the hood? Could be dirty/corroded connections. I don't think it is a difficult system to track thru the truck.
Old Aug 30, 2011 | 10:10 PM
b4hntn's Avatar
b4hntn
Amen to AzPete. I agree. I got mine from a travelling saleswoman who had not put it in 4WD in years. However, I did get lights and relay click. I shifted to neutral and pushed the 4Hi, 4Lo buttons for about a minute for several days and the shift motor finally freed up. Now I shift at least monthly and run in 4WD every time I am off road.
krave's Avatar
krave
I was also thinking corroded conections on the back of the switch but I will check the fuses.
Thanks
Old Aug 31, 2011 | 12:31 AM
greystreak92's Avatar
greystreak92
Definitely engage this system monthly. It not only keeps the shift motor and t-case mechanisms moving properly, it keeps the front differential gearing from self destructing the first time you use it. That ring gear and associated bearings sit there up front for weeks, months even years not getting ANY lube and the moisture/humidity in the diff casing causes the surface to flash rust repeatedly. Next thing you know, you engage the 4WD and you get about half a mile before the noise is deafening or the ring gear becomes a pile of little rusty shards in the bottom of the housing.
f250timmy
Mar 6, 2018 11:58 AM
einsteindog
Jan 22, 2009 02:51 PM
PW01
1983 - 2012 Ranger & B-Series
Jul 7, 2006 07:04 AM
nex813
Offroad & 4x4
Mar 26, 2004 05:58 PM
jfarmer
Feb 11, 2004 11:33 PM
