Sponsored by: Real Truck
No Heat
Old Aug 30, 2011 | 08:34 PM
Sully4755's Avatar
Sully4755
No Heat
Hello, A friend has a 2006 F250 4x4 with a 5.4. He has no heat. Blows cold through the vents on defrost or cold through the vents in dash. He says the heater hoses are warm. Any ideas?
Old Aug 30, 2011 | 08:48 PM
Pili's Avatar
Pili
More then likely the heater core is shot. If you don't mind me asking why is your friend trying to use the heater during the hottest time of the year?
Kajtek1's Avatar
Kajtek1
On my 99 SD there is no valve on heater hoses and the heater core is always hot. The temperature is adjusted by electronically controlled mixer and vacuum operated flaps.
So if his system is the same as mine, the mixer failed. You can find pictorial of the system repair here https://www.ford-trucks.com/forums/8...ater-core.html
hipockets2842
1978 - 1996 Big Bronco
15
Dec 23, 2010 08:06 PM
smoulding
Jul 31, 2007 03:51 AM
flfisher2002
Oct 3, 2006 09:35 AM
donaldson202
Aerostar
Mar 7, 2005 02:41 AM
