Corrosion on Surfaces
Old Aug 30, 2011 | 11:31 AM
p12483's Avatar
p12483
Unhappy Corrosion on Surfaces
I have noticed a good amount of rust forming on the surfaces of the bottom of the engine, drive shaft, rear differential, and other sufaces. It appears to only be on the surface. I'm new to heavy duties, and am not sure how Ford protects their sufaces. Just wanted to make sure this is normal and nothing to be concerned about and that they didn't miss treating these surfaces in the factory.
Old Aug 30, 2011 | 12:21 PM
Kep4's Avatar
Kep4
Jäger
Unfortunately, that's normal on Super Duties.
Spray some Fluid Film on those surfaces and your truck will be fine: Fluid Film® | Corrosion Preventative, Lubricant and Rust Inhibitor
Old Aug 30, 2011 | 12:36 PM
jack_pine's Avatar
jack_pine
A few threads on this. Some, it bothers a lot....others, not so much. I am in the latter clan. My '04 had that within moths and still has it. No worries.
Old Aug 30, 2011 | 12:40 PM
TxFordGuy1's Avatar
TxFordGuy1
I'm pretty sure mine was already like that when I picked it up.
Old Aug 30, 2011 | 02:26 PM
p12483's Avatar
p12483
Thanks for the info guys. Glad to know I'm not the only one
Old Aug 30, 2011 | 03:01 PM
Marauder92V's Avatar
Marauder92V
When my truck arrived it had rust on the stuff you wrote about. I sprayed Fluid Film on everything and this is a picture after a winter.
Basically stopped the rust that had formed and prevented anymore...
Old Aug 30, 2011 | 06:29 PM
kper05's Avatar
kper05
Parts of the drive shaft and other places on my truck were already showing rust spots when I picked it up with 4 miles on it at 14 days old.
I didn't spray anything on mine.
Looks bad but it sounds like it will be fine through the years.
Old Aug 30, 2011 | 08:19 PM
Dim Sum's Avatar
Dim Sum
Mine is the same way. I am gonna pick up some black rustoleum and this Fluid Film to help protect everything.
speakerfritz
May 4, 2018 06:40 PM
Sparky570
Nov 23, 2017 06:45 AM
speakerfritz
Apr 22, 2015 09:46 AM
savagefan
Jan 14, 2015 06:07 PM
dewking
1983 - 2012 Ranger & B-Series
Dec 17, 2010 12:39 PM
