Is this normal?
Old Dec 16, 2010 | 05:00 PM
dewking's Avatar
dewking
Is this normal?
2011 1 month old and my rear differential and rear axel are rusted. doesnt seem like it should already be rusting. the back side looks ok its just the front side and the drive shaft.
Regards
Dewking
Old Dec 16, 2010 | 05:15 PM
grandmas77f150's Avatar
grandmas77f150
Is it just surface rust? Have you been driving on salted roads?
Old Dec 16, 2010 | 05:39 PM
dewking's Avatar
dewking
no on the salt.. looks like surface rust, front side of diff, drive shaft and halfway up each side of the axel.
probably not a warranty issue? but i am going to check
Regards,
Dewking
Old Dec 17, 2010 | 11:44 AM
white cat's Avatar
white cat
They never paint that stuff in the factory, even here in so. calif they rust,the first thing I did when I got my 2002 was to get under it, and spray everything I could with black rustoleum paint,I can't stand rust on a new truck. I also paint the brake drums and calibers with silver high temp paint. Makes working on things easier later on.
Old Dec 17, 2010 | 12:39 PM
Nojive55's Avatar
Nojive55
If you want it to look original (as opposed to painting) just spray with Gibbs penitrating oil. It is wonderful stuff, penitrates at the molecular level keeping water and rust out. Reapply as needed, a couple of times a year ought to do it.
dewking
46
Jan 6, 2011 07:00 PM
dewking
Nov 20, 2010 12:40 PM
dewking
May 5, 2009 08:21 PM
dewking
Apr 27, 2009 11:00 AM
dewking
Apr 23, 2009 04:01 PM
