Just another ECT vs EOT story
Old Aug 31, 2011 | 06:36 AM
npccpartsman's Avatar
npccpartsman
Originally Posted by SoCalSuperDuty03
69cj, where did you get the 65 MPH/Level Ground info? It makes sense, but it obviously differs from what the Ford TSB states.
I never looked into the TSB as I've seen the 65 mph "standard" posted in so many places. Maybe it's another one of those "internet rumors" that someone got started and it just caught fire.
Old Aug 31, 2011 | 10:58 AM
texans's Avatar
texans
Same here. I have never actualy looked at the tsb until now. I guess that's what I get for sticking my foot in my mouth.
I could have swore that even Cheezit has stated 65 mph.
Either way it still makes more since to me than the wot thing.
Old Aug 31, 2011 | 11:08 AM
69cj's Avatar
69cj
From what I've read here, and what the local Ford diesel mech. has told me and also from monitoring the temps. everything points to the level ground and steady speed theory. If climbing or wot or cresting a hill and going down it you always have one temp chasing the other. For example after climbing and then cresting a hill the ect will crash in a matter of seconds where it will take the eot a matter of minutes to catch up to the ect. You could easily get a 30* or higher spread there. That is why you want everything stabilized to get a true delta.
Old Aug 31, 2011 | 08:08 PM
SoCalSuperDuty03's Avatar
SoCalSuperDuty03
I agree the stabilization of the fluid temps would seem like the best method to check for anomalies, but I wonder why FoMoCo would specify the WOT method?
I have a good friend who is a FoMoCo Master Tech; specifically a factory trained 6.9, 7.3, 6.0, 6.4 diesel guy, I will hit him up for a theory, or any documentation he may have.
Old Aug 31, 2011 | 08:11 PM
SoCalSuperDuty03
Don't feel like the Lone Ranger texans, I have had my foot in my mouth a time or two, and usually up to my knee...
Old Aug 31, 2011 | 08:20 PM
SoCalSuperDuty03
Originally Posted by bismic
05/12, '03, 05/07 6.0, Torqshift, CC, SB, 4WD, FX4 Sport, Sonic Blue/Grey, 8" Edge lift, six Foxes, Fox damper, 38x15.50x18 Toyo M/T's, Weld Renegades, Detroit Locker, 4.30's, Mag-Hytecs, ARP's, Hypermax HG's, Fluidamper, Spearco IC, MBRP 304, Trans; Converter and SCT tuning by John Wood, Custom Trac Bars, Onboard Air, AMP steps.... lots more
SoCalSuperDuty03 -
I like your truck!
(sorry for the hijack)
Thanks Mark, I have to say, out of the 40+ trucks I have owned over the last 30 years, this one is my absolute favorite. I still love it as much (if not more) than the day I drove it home in July of '03. This one has really been a labor of love, and other than the trans; no one else has had a wrench on this
truck.
The crazy thing is, I love all of our trucks... '99, '11, Gas, Diesel, 2WD, 4WD, lowered, lifted, all done up or stock as a rock, I love them all.
Old Aug 31, 2011 | 08:38 PM
SoCalSuperDuty03
Originally Posted by carmk
I have an interesting situation I would like your opinions on.
I had my EGR and Oil Cooler replaced about 5,000 miles ago. Since then I have towed about 4,200 miles across the West with little problem and lots of power.
I have noticed, however, that my EOT is sometimes BELOW by ECT. The oil temp will sometimes be lower than the coolant temp, even after the engine is fully warmed up.
Does this makes sense? Is this normal?
What device are you using to read the temps?
With my SCT datalogging, I was reading a bunch of different PID's, but the EOT and EOT farenheit were interesting to me, as the EOT farenheit never graphed correctly, reading in the 9-10k range. The EOT (not sure where the sensor is for this, if it is different than EOT f) read in normal temps, mirroring the ECT at times, but reading BELOW the ECT at other times.
That is partially why I gave up and hooked up the Snap-On scan tool, I was getting paranoid by the erroneous readings.
Old Aug 31, 2011 | 08:41 PM
SoCalSuperDuty03
cj, what local Ford tech. do you converse with? Dealer guy or independent guy?
Old Jan 8, 2012 | 12:21 PM
robs97z28's Avatar
robs97z28
So, what happen? did anyone ever find the correct way of finding the ect and eot deltas?
Old Jan 8, 2012 | 12:35 PM
BLADE35's Avatar
BLADE35
About all I can say on that is I used the 65MPH flat ground method
I came up with a 25* spread. When I changed and cut that oil cooler open it was plugged solid
so it seams that the 65MPH flat ground method was a Great Indicator
Old Jan 8, 2012 | 01:00 PM
69cj's Avatar
69cj
Two diff. Ford mechanics at two diff. dealerships. 65 mph is a number used since that's the speed limit and it gives everything a good saturation. I imagine 55 or 75 would also work as long as it's on flat ground and the temps have stabilized.
Old Jan 8, 2012 | 02:19 PM
Idahoser's Avatar
Idahoser
a clean oil cooler is going to work rapidly and well to bring the oil near the coolant temp. Either test should tell you whether that's happening or not. If the oil takes a long time to come back down after hard work, or if the oil steadily goes way above the coolant on a steady run, they're both telling you the oil cooler is inefficient. That's the point of the test.
Jtpadilla1030
Jan 16, 2018 09:51 PM
MYWEIGH
Dec 16, 2013 08:30 AM
dieselsmoker
6.4L Power Stroke Diesel
May 30, 2013 07:47 AM
exiled
Nov 24, 2012 12:35 PM
Bob2626
Dec 31, 2011 09:43 PM
