EBPV Question
Old Aug 29, 2011 | 11:21 AM
Blackdog 15's Avatar
Blackdog 15
EBPV Question
I posted the following under the delete thread also..am in the middle of this and need some answers..Thanks...
Question....if you decide to weld the pedestal ...do you have to weld the hole where the rod comes out and the other larger end where the snap ring and cover plug are ? I saw one video where the guy tapped the rod hole for 1/4" pipe threads, put in a plug, then re-installed the large plug and snap ring on the other end... also have seen the large end cut off at an angle and welded shut along with the small rod hole..either way..no problem (am a heliarc welder by trade)...do aluminum pressure work daily...just want to know what works best...
Also when you drop out the butterfly from the turbo outlet (just ground out the 2 rivets & removed it and the shaft....is all I need to do to complete this operation is install a 3/4" freeze plug in the one side to seal it up.. I noticed there is a small snap ring/split ring on the outside of the bushing..I assumed that it can be removed too...
Old Aug 29, 2011 | 11:53 AM
cowmilker08's Avatar
cowmilker08
Those solutions will work just fine.
The main thing is just to make sure you got the valve, rod, and bushings out. Then just plug the hole by whatever method you prefer.
My friend was swapping to a larger turbo after blowing up his stock one, so I just took his upper freeze plug and put it in the lower hole on my housing. Then I welded it in just to be sure.
There shouldn't be a too much pressure there unless you are still running a clogged up catyltic converter.
Old Aug 29, 2011 | 01:24 PM
Blackdog 15
I'm running a 5" exhaust, no Cat....just heliarc welded the rod hole in the pedestal, am re installing the plug with O ring on other end & snap ring...
Old Aug 29, 2011 | 04:16 PM
91 Dually's Avatar
91 Dually
Mine was leaking oil all down the back of my engine. Therefore, my thoughts were "get rid of anything that can later cause an oil leak. I removed everything, cut the crap out of it with a sawzall and grinder, welded up the holes. No More Leaks
Old Aug 31, 2011 | 11:38 AM
cowmilker08
that is an awesome truck!
Old Aug 31, 2011 | 07:27 PM
Blackdog 15
moving new cab
Old Aug 31, 2011 | 08:12 PM
91 Dually's Avatar
91 Dually
WOW!! and I thought I had a lot of work to do. I feel fer ya pal
Old Aug 31, 2011 | 08:17 PM
91 Dually's Avatar
91 Dually
Thanks, Cowmilker... She is still a work in progress. She has been somewhat neglected in the past, but I intend to fully restore her.
Old Sep 2, 2011 | 12:04 PM
cowmilker08
If that is neglected then my truck is down right abused!
B-Rad88
Jan 20, 2018 08:48 AM
bike_guy123
Jan 22, 2013 08:50 PM
03power73stroke
Nov 12, 2010 04:44 AM
RubberDuck
Aug 15, 2006 05:24 PM
94 1/2 stroker
18
Mar 5, 2006 03:52 AM
