radiator size?
Old Aug 28, 2011 | 10:35 PM
turbo diesel fan's Avatar
turbo diesel fan
radiator size?
i recently had my radiator go out and its been sitting for awhile and my moms friend got rid of it and im trying to find the right size. ive seen many sizes like 23 1/4 x 30 1/4 and 23 1/2 and 30 1/2 i know it has to be 30 in long but what correct size is needed in a 1994 f250?
Old Aug 28, 2011 | 10:45 PM
IDIDieselJohn's Avatar
IDIDieselJohn
There were only 2 different sizes for these engines.
Don't know the sizes, but everyone knows 'em by the "short/wide" one and the most common, "tall narrow" one.
Old Aug 29, 2011 | 08:08 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
https://www.ford-trucks.com/forums/9...l#post10513622
i don't think they messed around with the 9th gen idi trucks (92-94) with diff size rads.a/c or not,i think they all used used the same size.but i don't know this for sure.like 50% sure
just look up rads at diff parts places online and see if you see anything for size options......i sure don't remember there being any when i looked.shoot,even that 8th gens i think all used the taller rads too.though maybe back then it was based on A/C or not.heck if i know lol.
Old Aug 29, 2011 | 09:23 PM
IDIDieselJohn
I know on LMC trucks, (for the 87-91 models) theres 2 Rad options, 1 is without super cooling option, and the other is WITH super cooling option.
Wonder if that has something to do with the tall narrow rad and the short wide one?
Was really common to see short wide ones on A/C trucks for some reason, but I did see some short wide ones on non A/C trucks to.
Ford loved making people wonder sometimes I guess
Old Aug 29, 2011 | 09:35 PM
88beast's Avatar
88beast
get a rad out of a psd and the brackets for it and itll work great and cool better i got one
Old Aug 30, 2011 | 10:35 AM
turbo diesel fan
i got a tall and narrow with factory a/c so i hope any radiator will be able to cool it and the truck 2
Old Aug 30, 2011 | 10:40 AM
turbo diesel fan
http://cgi.ebay.com/ebaymotors/3-Row...item2c5d6a1701
will u guys check this out and see if this will work? i had my eyes on this one for awhile. and please be honest on your opinion it would be much appreicated
Old Aug 30, 2011 | 06:21 PM
FORDF250HDXLT
3 Row Radiator 1983-1994 F-Series Pickup Truck Diesel | eBay
you'll need a different type of coolant for aluminum rad or heater core.
coolant and SCA's designed for aluminum,but it cannot be ELC either (some people think ELC coolant is ok for older engines as well......why? i donm't know.lack of research for one,for sure.they think they know better than navistar or ford for reason #2 i guess?)
you'll also need to ditch that 16 lb cap and replace it with a 13 lb cap.
a lot of people blindly run aluminum parts in place of the factory copper/brass without first researching things.mostly because this is mainly what the aftermarket/replacement parts are made of now due to the price of copper.
aluminumvscopper
The thermal conductivity or heat transfer rate of copper is 92% versus aluminum which is approximately 49%.
i didn't post how to get the copper/brass rad for pretty much the same $ as the aluminum just for the heck of it.
but if your set on aluminum and need help finding a proper diesel coolant,let me know.i can research to see what id use if i was stuck buying the aluminum (but iv got to tell ya,id just buy a used copper/brass first.)
edit;
found what you need real quick actually:
Originally Posted by Dave Sponaugle
Read some of the articles about SCA's and silicates.
Antifreeze companies use silicates to protect aluminum radiators.
Silicates and SCA's are not the best of friends.
I will stick with a brass radiator and heater core, then there is no aluminum, no need for silicates to protect what is not there.
So I can keep running low silicate antifreeze like I do now.
I am running one of the ebay aluminum radiators, and I am using the Zerez G05 coolant. Dave S is correct, if you are going to run a aluminum radiator or heater core, you will have to plan what coolant to use if you want it to last.
what SCA's to use with that though? not sure.you'll have to research a little,iv never taken the time.
on top of this,you'll also what to research and how to test for electrolysis when going with aluminum as well,if you want the thing to last that is.
timbuctooCal
Dec 12, 2018 11:50 AM
queen of spades
Feb 24, 2015 11:02 AM
1954_NJ_F100
Mar 7, 2013 09:10 PM
kupaa
Mar 18, 2012 01:01 PM
