Sponsored by: Real Truck
drive shaft clunk
Old Aug 28, 2011 | 09:13 PM
aprice's Avatar
aprice
drive shaft clunk
i have noticed a slight clunk at take off. figuring it was a u-joint i got under the truck today and found all the joint to be tight still. I did find at the transfer case rear output yoke there is play between the yoke and drive shaft flange, almost like the bolt holes are egg shaped. the bolts are super tight. i had a socket with a 12" breaker bar and was almost doing pull ups under the truck.
so has anyone else have this issue, or whats the best fix? (its the truck in my sig)
Old Aug 28, 2011 | 09:16 PM
Quad Racer's Avatar
Quad Racer
Do a search of this forum. I believe there has been other threads regarding this.
Old Aug 28, 2011 | 09:48 PM
aprice's Avatar
aprice
Every thing i have found points to a slip yoke clunk but i know theres movement at that flange
Old Aug 28, 2011 | 11:16 PM
KOESTNER's Avatar
KOESTNER
I am following this because I also have the same clunk at the TC tail shaft and not the slip joint. Slip joint has been greased with Ford PTFE lubricant with no change. Please report your results to this thread if a correction is found. All searches indicate the slip joint which it is not.
Old Aug 29, 2011 | 12:37 AM
hotroddsl's Avatar
hotroddsl
Well......the most common cause IS the slip yolk! However that does not mean the only cause, second most common cause is a bad universal joint usually the rear, the least common is a worn companion flange I have only come upon this once when the wrong (shouldered) bolts were installed at the differential side on the one I had this did no allow enough holding force when the shoulder bottomed out just after contact with the flange surface after several months or years of operation the holes on the shaft flange wore out to twice the original size before bolts started braking customer never complained because it happens ^so gradually it just grew on hew and she thought it was normal!
Jim...& fat Monty
Old Aug 29, 2011 | 04:20 AM
mountie's Avatar
mountie
My first thought would have been some wear in the rear Diff. But I can't wait to see what you find. Hopefully it's not expensive.
Old Aug 29, 2011 | 04:55 AM
ford390gashog's Avatar
ford390gashog
Check the rear axle pinion for movement.
Old Aug 29, 2011 | 06:09 AM
Benchwrench's Avatar
Benchwrench
Grease it first then see if you have any further complaints. Chances are it's just a lack of lube.
Slip joint regreasing
Old Aug 29, 2011 | 12:20 PM
racsan's Avatar
racsan
maybe its a combination of a little play at the slip yoke & the normal pinion backlash?
northerndave
Dec 7, 2012 08:59 AM
Murf_2002_F150
1997 - 2003 F150
Sep 2, 2010 02:48 PM
jsparrow
Sep 11, 2009 02:50 PM
rlh
1978 - 1996 Big Bronco
Jan 19, 2004 11:44 PM
first time 4x4
Mar 16, 2003 07:07 PM
