ABS/BRAKE light on
Old Aug 28, 2011 | 06:23 PM
quesey's Avatar
quesey
ABS/BRAKE light on
was having such good luck until the other day with this truck.hit a big bump and my abs and brake light came on.now when i hit even a small bump its kicking my convertor in an out like i hit the brake pedal.
any ideas where to look i checked all the wiring around the master cyl.they seam like they are still hooked up and working but did'nt know if they are what controls these systems
thanks john
Old Aug 28, 2011 | 10:00 PM
pjwoolw's Avatar
pjwoolw
Check the RABS valve. There will a connector there. Give it a look.
Old Aug 29, 2011 | 05:28 AM
quesey's Avatar
quesey
ok will do
thanks
Old Aug 29, 2011 | 05:36 AM
ford390gashog's Avatar
ford390gashog
First I would pull the RABS codes
https://www.ford-trucks.com/forums/1...r-lock-up.html
https://www.ford-trucks.com/forums/1...abs-codes.html
Old Aug 29, 2011 | 12:05 PM
RRranch's Avatar
RRranch
amber abs and red brake light on at the same time means a fluid problem. Low fluid level. If your master is full then it is almost always a loose or corroded connector on the sensor in the bottom of it. They are especially good about doing it when you hit bumps if it is loose and or corroded.
Old Aug 29, 2011 | 10:28 PM
Talyn's Avatar
Talyn
I'd check the parking break wire as well, just for ****s and giggles. =)
It's right on the p-brake pedal under the dash.
mchammer
Oct 9, 2006 08:21 AM
4Wheelz
Nov 8, 2005 10:32 PM
ColonyPark
1983 - 2012 Ranger & B-Series
Jul 28, 2005 08:20 PM
00RedExpedition
Sep 10, 2002 03:22 PM
