Scan Gauge 2
Old Aug 28, 2011 | 11:19 AM
Randy777's Avatar
Randy777
Scan Gauge 2
Althrough I already have gauges I was thinking of getting the Scan Gauge 2 to add more info. I know it does battery voltage but does it also do FICM voltage? Can it monitor fuel pressure with an adapter too? Does it do anything else that can be useful? As I said above I have most gauges except for fuel pressure and oil pressure. Thanks for the info.
Old Aug 28, 2011 | 11:36 AM
npccpartsman's Avatar
npccpartsman
It will NOT do fuel pressure, EGT's or engine oil pressure since there aren't any PCM sensors to monitor those functions. Here's my short list:
Scan gauge inputs: ScanGauge II XGauge codes - GasSavers.org - Helping You Save at the Pump Hypermiling and Fuel Efficiency Forum
FORD 6.0 L Diesel:
GAUGE TXD RXF RXD MTH NAME
FL 07E02216C1 0462451606C1 3010 000101480000 Fuel Level
VRF 07E0221155 046205110655 3010 006433330000 VREF (CALIBRATION VOLTAGE INPUT)
BAT 07E0221172 046205110672 3008 000100010000 BATTERY VOLTAGE
ECT 07E0221139 046205110639 3008 000200010000 ECT Degrees F
EOT 07E0221310 046245130610 3010 00090005F05F EOT Degrees F
TFT 07E1221674 046205160674 3010 000100080000 TFT Degrees F
IAT1 07E0221123 046205110623 3010 000100010000 IAT1 Degrees F
IAT2 07E02216A8 0462051606A8 3010 000100010000 IAT2 DEGREES F
ICP 07E0221446 046205140646 3010 003900640000 ICP PSI
ICV 07E02216AD 0462451606AD 3010 004827100000 ICP voltage
IPR DC% 07E0221434 046285140634 3008 0DCA03E8000A IPR %
INJPW 07E0221410 046245140610 3010 044C04E2FFF1 FPW Microseconds (table)
INJPW 07E0221410 046205140610 3010 000800010000 FPW Microseconds (modified)
ITM 07E02209CC 0426850906CC 3010 000A00400000 INJECTOR TIMING BTDC (DEGREES)
MFD 07E0221412 046245140612 3010 006400100000 MFDES Mg per Stroke
MFD 07E0221412 046245140612 3010 000100100000 MFDES (ALT)
VFDES 07E0221411 046245140611 3010 006400100000 VFD Cubic mm
FMP 07E02209D0 0462450906D0 3010 006401000000 FICM Main Power (Volts 47-48)
FVP 07E02209CE 0462450906CE 3010 006401000000 FICM VEHICLE POWER (SHOULD BE 12 VOLTS)
FLP 07E02209EF 0462450906CF 3010 006401000000 FICM LOGIC POWER (SHOULD BE 12 VOLTS)
FSN 07E02209CD 0462050906CD 3601 000100010000 FICM-sync 0=NO, 1=Yes
SYC 07E02209CD 0462050906CD 3000 000100010000 SYC CAM/CRANK POSITION SENSOR SYNC (1= IN SYNC)
SYC 07E02209CD 0462050906CD 3001 000100010000 SYC ALTERNATE
SYC 07E02209CD 0462050906CD 3701 000100010000 SYC ALTERNATE
FSS 07E022099F 04620509069F 3010 000100040000 FAN SPEED SENSOR
FDC 07E022091F 04624509061F 3010 013103E80000 FAN SPEED DUTY CYCLE
Baro 07E0221127 046285110627 3008 003100500000 BAR Inches of Mercury
EBP 07E0221445 046285140645 3010 001D00500000 EBP PSI
EBP 07E0221445 046285140645 3010 001D0050FFFB EBP (-0.5 PSI)
BST 07E0221440 046285140640 3010 01220320???? PSI/BST MAP Modified signal PLUG IN VALUE FROM TABLE FROM YOUR MAP
MAP 07E0221440 046285140640 3010 012203200000 MAP EXTENDED RANGE
14.0 -- FF74
14.1 -- FF73
14.2 -- FF72
14.3 -- FF71
14.4 -- FF70
14.5 -- FF6F
14.6 -- FF6E
14.7 -- FF6D
14.8 -- FF6C
14.9 -- FF6B
15.0 -- FF6A
Old Aug 28, 2011 | 02:05 PM
69cj's Avatar
69cj
I might add a comment to Tim's list. That's a hell of a lot of monitoring for $159 bucks. See what that many gauges would cost. It can also read certain DTC's.
Old Aug 29, 2011 | 11:47 AM
Misky6.0's Avatar
Misky6.0
Randy,
The SGII only reads via the ODBII port the existing Ford sensors.
The fuel pressure, oil pressure, and exhaust gas temp are the
most common things that require you to add your own sensors
AND gauges - since Ford doesn't monitor those with the computer.
The dashboard oil pressure is really a glorified idiot light:
indicating there IS or is NOT oil pressure greater than 5 or 7.5 PSI.
The SGII also give you access to trip and fuel mileage data which is
also very informative.
Old Sep 1, 2011 | 11:21 AM
powerstroker100's Avatar
powerstroker100
where can you buy a scan gauge 2, does any autopart store carry them
Old Sep 1, 2011 | 11:32 AM
HowarD1's Avatar
HowarD1
Got mine from Amazon.com. I mounted it above the mirror with the Blend Mount....also from Amazon.com.
Old Sep 1, 2011 | 01:47 PM
klbrown's Avatar
klbrown
I got mine through cleanmpg.org. If you join their forum you can get it for about $132. Shipping was quick.
I haven't decided on a permanent mounting yet but currently have it
mounted inside the ashtray with velcro, on the bottom edge just behind the latch. You can close the ashtray when not using it.
Old Sep 1, 2011 | 03:00 PM
bopfly's Avatar
bopfly
I have one for sale for $75 shipped. Just e-mail me at aviles613@aol.com if you want it. It's less than 6 months old. Just sold the truck and don't need it. Some X-Guages already loaded.
Old Sep 1, 2011 | 03:47 PM
jimmyv13's Avatar
jimmyv13
check email.
Old Sep 1, 2011 | 08:44 PM
Monster-4's Avatar
Monster-4
Attached is a PDF I made of the codes npccpartsman posted. Should make it easier to save offline and I also made it in a printable format.
2003-2007 Ford Super Duty 6.0L ScanGauge II XGauge Codes.pdf
Old Sep 1, 2011 | 09:13 PM
BLADE35's Avatar
BLADE35
and since the SG uses the factory senders you see what the PCM is seeing and the info is not corupt
depending how the after market gauges are ran they may have a biased reading and may not be correct due to sender location and wiring issues
its well woth the money Iv caught a few issues with mine before catastropic failure so its paid for itself 10 times over
Old Sep 2, 2011 | 06:07 AM
npccpartsman
Attachment 40897
NICE!!!!!! Rep'd ya.
Old Sep 2, 2011 | 08:43 AM
Monster-4's Avatar
Monster-4
No problem and thanks for posting the codes. Feel free to distribute the PDF.
cps
Sep 5, 2017 01:50 PM
sunogbahay
Jun 7, 2016 09:45 AM
helloimjason
May 14, 2015 05:19 AM
Sheryle
Feb 28, 2011 04:39 AM
moebdick
Jan 16, 2011 07:18 PM
