High LPOP Pressure
Old Jun 6, 2016 | 09:51 PM
sunogbahay's Avatar
sunogbahay
High LPOP Pressure
I noticed this evening that my low pressure oil pressure was much higher than normal. I have a LPOP gauge that typically reads 12 psi or so at idle. This evening I was seeing 75psi with a warm engine. Every little acceleration pegged the gauge over 100psi.
The factory non-functioning gauge says that everything is normal.
How concerned do you think that I should be?
I am about due for an oil change. I was thinking that I would change the oil and filter as soon as possible and temporarily plumb in my mechanical gauge to see if the high pressure reading is real or not. I replaced the stock LPOP about 3 years ago with a melling and everything has been golden up until now.
Any other ideas for things to check?
Old Jun 6, 2016 | 10:27 PM
AllaboutMPG's Avatar
AllaboutMPG
What brand of gauge. I'm assuming its aftermarket. I've had 2 sending units go bad for fuel pressure and when they went they were indicating high. Might not be actual oil pressure
Old Jun 7, 2016 | 08:19 AM
sunogbahay's Avatar
sunogbahay
The gauges that I have are isspro ev2's. They've been installed for about 5 years.
Old Jun 7, 2016 | 08:47 AM
Tugly's Avatar
Tugly
Sounds like a sensor to me. Do you have any other EV2 pressure gauges? Many of the sensors are 0-100 PSI with a range of 0-5 volts output. My Fuel pressure gauge doubles as a boost gauge, I just installed a switch to select the function I need at a given time. You can take a fuel pressure sensor and swap it to the oil pressure port.
Old Jun 7, 2016 | 09:19 AM
timmyboy76's Avatar
timmyboy76
Hit up Tugly's magic kingdom (Harbor Frieght), get yourself a 18" flexible grease gun hose, a 0-100 liquid filled gauge, a 1/8npt coupling(to connect hose to gauge), and then find yourself a hydraulic store and get a #4orb X 1/8npt(f) adaptor... Then plumb gauge setup to the hpop resivoir plug and fire up truck
Old Jun 7, 2016 | 09:31 AM
AllaboutMPG
misread.....nevermind
Old Jun 7, 2016 | 09:45 AM
Tugly's Avatar
Tugly
Originally Posted by timmyboy76
Hit up Tugly's magic kingdom (Harbor Frieght)....
Owe gawd....
88F15095F150
30
Feb 22, 2017 06:33 AM
puffen:D
21
Mar 16, 2015 06:36 PM
NorthernWild
Aug 1, 2014 07:26 AM
Josh88Ford
Feb 13, 2011 06:04 AM
abendx
Jan 15, 2003 06:15 PM
