keyless entry
Old Aug 28, 2011 | 10:44 AM
rodneywar's Avatar
rodneywar
keyless entry
i was thinking about swapping over the remote keyless wiring harness and module from my 1997 to 1996 trucks both are psds and 1996 is a 4x4 while the 1997 is 4x2 would there be any snags i would hit if i do this? i have everything needed to do this.
Old Aug 28, 2011 | 11:50 AM
quesey's Avatar
quesey
is the 96 ele locks allready?if so most trucks i've seen with ele locks had the stuff there to use the fob on.i may be wrong on it but look under the dash think its a grey plug you have to jump to program you fob to the truck. i just found the plug after reading on here on some older post and picked up a fob and got it to work for me
good luck
Old Aug 28, 2011 | 12:31 PM
rodneywar's Avatar
rodneywar
i checked that no module there and yea it is a electric locks but with the xlt trucks some had it some didnt the xlt lariat all had em
Old Aug 28, 2011 | 04:59 PM
chicagodragon's Avatar
chicagodragon
even if it has electric locks, you will have to swap over alot of wiring. alot of things run through the keyless entry box. lights, horn, locks... after having done my conversion, i found out the door lock wiring is very differnt
Old Aug 28, 2011 | 05:19 PM
joe_13894's Avatar
joe_13894
I would suggest just buying an aftermarket system. They are easy to put in. Simple ones are available for less than $40.
If you don't care about the horn honking or the lights blinking you don't have to tap into those wires.
Old Aug 28, 2011 | 05:21 PM
chicagodragon
i agree, even the aftermarket systems will allow for the lights and horn. most of them hook up to everything right under the dash
Old Aug 28, 2011 | 07:33 PM
rodneywar's Avatar
rodneywar
isnt all the wiring inside the dash? i have a swappable dash both are exactly the same but one is rke one isnt
Old Aug 28, 2011 | 08:13 PM
chicagodragon
I think so, it's been awhile. I think you would have to swap all the wiring up to the firewall and possibly splice it at the doors because I think they have different plugs
Old Aug 28, 2011 | 10:50 PM
joe_13894's Avatar
joe_13894
An aftermarket is easier because Ford wired the RKE trucks different. The aftermarket units are configurable to work with any kind of door lock wiring.
Old Aug 29, 2011 | 01:55 AM
GreaseMonky's Avatar
GreaseMonky
How can you tell if they had it or not, my 94.5 has a theft light that blinks on the dash, and if i open a door that has been locked without the key my lights flash like an alarm is going off, and i have to put the key in the lock to get it to stop, it also has elec locks.
Old Aug 29, 2011 | 04:10 AM
Copedawg's Avatar
Copedawg
Comprehensive Chevrolet, Saturn, GMC, Hummer, Cadillac, Buick, Oldsmobile, Pontiac, Geo, Dodge, Plymouth, Jeep, Chrysler, Ford, Lincoln, Mercury, Mazda Truck, Mercedes VIN Decoder
Old Aug 29, 2011 | 04:48 AM
ford390gashog's Avatar
ford390gashog
The trucks without factory keyless entry used much different 5 wire reverse polarity wiring. Just use an aftermarket set up.To swap the OEM one is way to much work and it is not that great of a system.
Old Aug 29, 2011 | 10:42 AM
superduty4x4's Avatar
superduty4x4
Nope the entire interior wiring harness is different. My friend strokersace found this out the hard way trying to do exactly what you are doing... PM him and he might chime in.
wr310rdr
Jul 22, 2013 12:09 AM
AllaboutMPG
Oct 20, 2011 09:30 PM
RMS94
Jan 21, 2007 12:13 AM
marshall99f150
1997 - 2003 F150
Jul 28, 2006 12:47 PM
belzurkur
Dec 5, 2002 10:27 AM
