Sponsored by: Real Truck
Keyless won't Program
Old Oct 19, 2011 | 12:43 PM
AllaboutMPG's Avatar
AllaboutMPG
Hi All,
Posted this in Electrical but not getting any response. Posting here hoping for some help.
Have already fixed the weak lock motors on my 2000 F250 thanks to the great info on this site. Now I can't get the truck to go into programming mode. I know it has Keyless entry, as I located the relays and identified the wiring while trying to fix the weak locks before I found the fix here.
I've tried the key on off 8 times but the locks never cycle. I've tried it with the driver door open and closed, cycling the locks from unlocked to locked to unlocked before cycling the ignition switch. Tried cycling the ign switch 5 times, 8 times and 10 times. No help. Any ideas???
Thanks in advance, Paul
<!-- / message -->
Old Oct 19, 2011 | 12:54 PM
bpounds's Avatar
bpounds
I'm not so sure that you have the option. What trim level is the truck? Is it a Lariat?
Old Oct 19, 2011 | 12:58 PM
AllaboutMPG
It's an XLT. I have a friend who has an automotive program that includes wiring diagrams. There are diagrams for "with" and "without" keyless entry and the components(relays), locations, numbers of wires, and wire colors all match the "With" Keyless entry configuration.
Old Oct 19, 2011 | 01:19 PM
bpounds's Avatar
bpounds
I can tell you that keyless was only an option, not standard on your XLT. The fact that it won't respond to programming is good evidence that you don't have that option on the truck. It is always possible that you have it and something is inop.
My best guess is that your schematic for "without KE" is for XL trucks. Keyless was not available on the XL level.
Old Oct 19, 2011 | 05:42 PM
AllaboutMPG
My truck has wires going to the GEM and the lights as called for in the wire diagram for "with keyless entry". When you look at the plug for the driver door lock switch the number of wires and the color coding of the wires match the "with" keyless entry wire diagram but definately do not match the "Without" diagram.
Is the logic and reciever for the keyless part of the Gem or seperate. I didn't see a receiver of any kind in the wire diagram.
Old Oct 19, 2011 | 06:50 PM
BigAlsPSD's Avatar
BigAlsPSD
If you are certain you are getting to the setup properly then you might have a GEM issue.
For programming a keyless entry fob for your vehicle, just use the following directions:
Insert a key in the ignition and without starting your car, turn the key from OFF to ON eight times in rapid succession (within 10 seconds) with the eighth turn ending in the ON position.
The doors will lock/unlock to confirm that programming mode has been entered.
Within 20 seconds, program a remote transmitter by pressing any button on the transmitter. The doors will lock/unlock to confirm that the remote transmitter has been programmed. If more than 20 seconds pass before pressing a remote transmitter button, the programming mode will exit and the procedure must be repeated.
Repeat the previous step to program additional remote transmitters. The doors will lock/unlock to confirm that each remote transmitter has been programmed.
When you have completed programming the remote transmitters, turn the ignition to OFF, or just wait 20 seconds. Again the doors will lock/unlock to confirm programming has been completed.
Old Oct 19, 2011 | 08:39 PM
AllaboutMPG
I was hoping it wasn't the Gem. In the past Gem problems gave themselves away with other symptoms like windows not working and dome lights not working etc.
Saw where someone had to lock and unlock their doors several times before starting the sequence. Will try that.
Old Oct 19, 2011 | 08:55 PM
BigAlsPSD's Avatar
BigAlsPSD
Are you simply basing your having the keyless system on wiring? It may not be the GEM, you might not have the option, I think if you took your VIN to a dealer they can tell you for sure.
Old Oct 19, 2011 | 09:01 PM
dchamberlain's Avatar
dchamberlain
Your Owner's Manual is a bit vague. It says to cycle the key 5 times, but stop at the 8th time.
I'd make sure you are starting at the right position (OFF, not LOCK) and are stopping in the ON position. I'd try 5 times and see what happens.
Old Oct 19, 2011 | 10:04 PM
AllaboutMPG
Thanks for the replies. Will try it again. May have been going to the lock position instead of off. If it doesn't work I'll stop by the Dealer tomorrow and see if they can help.
Old Oct 20, 2011 | 07:08 PM
AllaboutMPG
Went by my local dealer today and service manager says they only have access to build sheets by VIN number going back 10 years. Gave me an 800 customer service number to call to see if I could get help from corp. We'll see.
Old Oct 20, 2011 | 09:21 PM
pallain's Avatar
pallain
I am interested in the outcome
I bought an 2000 f350 two weeks ago and was curious if I have them also. thanks
Old Oct 20, 2011 | 09:30 PM
BigAlsPSD's Avatar
BigAlsPSD
Did you try the programming instructions, if the locks cycle you have keyless entry, and would just need fobs.
kink1950
Jul 9, 2011 05:39 PM
ldfry001
13
Feb 26, 2008 12:55 PM
swervin22
Jan 8, 2008 04:25 PM
free2grab
Nov 2, 2003 04:27 PM
COLTOPDOG
1997 - 2003 F150
Mar 6, 2003 02:59 PM
