1996 Keyless Entry Add
Old Dec 3, 2002 | 12:40 AM
belzurkur's Avatar
belzurkur
Hello Gents,
I have a '96 XLT and I would like to add the factory keyless entry. Has anyone done this?
The factory electric locks are already there, and I assume it's the same harness for all trucks with or without keyless. Can I just find a transmitter/receiver set and plug it in?
Thanks!
Old Dec 3, 2002 | 06:20 PM
steve83's Avatar
steve83
I have a '96 EB Bronco that I'm parting out, and I've pulled the keyless entry module. It appears to me that the lock wiring harness is different from the non-remotes.
Old Dec 3, 2002 | 06:26 PM
belzurkur's Avatar
belzurkur
[updated:LAST EDITED ON 03-Dec-02 AT 07:27 PM (EST)]Darn, that's my luck.
Does the Bronco that you are parting out have the factory side steps by chance?
Old Dec 3, 2002 | 11:21 PM
steve83's Avatar
steve83
It probably DID, but the thieves stripped all the easy-to-remove stuff, which is why I was able to buy a '96 & part it out!
http://www.webphotos.com/list_photos.asp?mi=3&smi=2&a=95012
Old Dec 4, 2002 | 02:27 PM
slave2dafords's Avatar
slave2dafords
Old Dec 4, 2002 | 03:47 PM
markus's Avatar
markus
I have a 95 F150 XLT with Power Locks - I took the dash apart and started comparing the wiring I had to the wiring in the manuals and sure enough non Keyless Entry locks are different. I was hoping to plug and play a factory module so it looked stock but you can with doing so pretty custom wiring which I don't have time for now I may get around to it some day. If you are interested though the best place to access your door lock wires in a non-keyless truck is behind the passager kick panel.
Old Dec 4, 2002 | 06:50 PM
steve83's Avatar
steve83
A better system is the Bulldog R114 keyless entry/remote starter. $50 at Sam's Club.
Old Dec 4, 2002 | 07:12 PM
belzurkur's Avatar
belzurkur
How good is the range on the Bulldog? I have had a clifford unit and a code-alarm unit. The clifford was a dog for range, never more than 30ft...even with a new battery. Code-alarm is an OEM supplier, that baby would hit even at 150ft and I never changed the battery.
Old Dec 4, 2002 | 09:46 PM
steve83's Avatar
steve83
I've put them in my mother's Grand Marquis, my brother-in-law's Bronco, and my girlfriend's MR-2. All had great range, but I never tested them. It never failed when I could see the vehicle, but their website should tell the nominal range. It's a really nice kit with EVERYTHING you need, including internal relays, a video, a knife, zip ties, tape, splicing instructions, wiring colors, and even a spiffy little LED test light! At $50, it's an outstanding deal compared to ANY keyless entry ONLY system. If you have a manual transmission, you can't use the starter function safely, but it's still cheap and good.
Old Dec 5, 2002 | 10:27 AM
92Pony's Avatar
92Pony
[updated:LAST EDITED ON 05-Dec-02 AT 11:31 AM (EST)]Ooops...nevermind.
Wade
presidentsdad
40
Sep 29, 2023 03:51 PM
crozz
2004 - 2008 F150
Sep 26, 2016 08:16 AM
racin
1997 - 2003 F150
Mar 13, 2016 08:59 PM
260karl
Sep 2, 2015 05:32 AM
fordguy2236
1997 - 2003 F150
Jul 13, 2013 09:49 PM
