Bad U-joint can pull you around
Old Aug 27, 2011 | 08:48 PM
Iallwork's Avatar
Iallwork
It's amazing how much a bad U-joint can mess up your steering and pull you around when it's the the one next to the front wheel. Anyone ever have that happen? I had a real bad wobble also. Front joint was so bad I couldn't bend it without the help of a pipe. I'm surprised I could turn a corner. It's my own fault for not greasing it enough.
Old Aug 27, 2011 | 11:41 PM
joe_13894's Avatar
joe_13894
Was it a greaseable joint? I thought the stock ones weren't greaseable.
What usually happens if you never engage 4x4 is that the axle shaft will turn until it is sitting such that only one of the two joints turn when you turn the wheel. The other joint won't move at all. What happens is the seals dry out and the needles and seat rust from sitting in one place. Then what happens is the shaft moves a tiny bit and now the one that has gone bad will be the one lined up with the knuckles. Since it's hard to turn it messes with your steering.
The best thing you can do to keep them in good shape is to put it the transfer case into 4x4 once in a while when the hubs are disengaged. A good idea is to do it for a few blocks every time you fuel up. This gets the seals and grease moving around in the joints. If you run around in the winter with the hubs locked then you don't need to then. If you have auto hubs only leave it in 4x4 for a few feet pulling out straight. When you take the transfer case back out of 4x4 the hubs will stay locked until you back up.
DarkyDizzle13
Dec 31, 2017 06:24 PM
JCS94
Dec 10, 2015 06:15 AM
vibrancy
Mar 28, 2010 12:35 PM
cmjenkins
Modular V10 (6.8l)
Jan 27, 2010 08:55 PM
865.0F150
Oct 27, 2006 09:37 PM
