Injector crush washers
Old Aug 27, 2011 | 08:39 PM
eatont9999's Avatar
eatont9999
Could one of you studious gentlemen/ladies post a link to where I can buy the copper crush washers used to install injectors? It couldn't hurt to post a link to the O-rings as well for anyone who may come across this thread.
I don't know the correct size otherwise I could help myself better.
Much appreciated.
Old Aug 27, 2011 | 10:08 PM
LSO1123's Avatar
LSO1123
I don't know about just the washers but you can buy a return line kit on ebay for like 25 bucks that comes with the copper washers and o rings. If you are just needing a set of copper washers, I have several. I'll send you a set if you want.
Old Aug 28, 2011 | 02:06 AM
91dirtydiesel's Avatar
91dirtydiesel
Viton orings #111 are much better than any that come in a kit, buy a pack on amazon for cheeeeeeep. as far as the copper washers go, I've only ever had them in the return line kit, I will look at them in the morning and see where to get them
Old Aug 28, 2011 | 03:16 AM
ford390gashog's Avatar
ford390gashog
McMaster-Carr has the o rings and may have the copper washer if you knwo the size!! I pay 7.00 for 50 viton o rings.
Old Aug 28, 2011 | 11:16 AM
eatont9999's Avatar
eatont9999
ID = 7mm
OD = 15mm
Thickness = 1/16" or about 1.5mm
This is according to my cheap, plastic calipers. I miss my real set.
Old Aug 28, 2011 | 10:32 PM
ford390gashog
mc master has them but its 12.00 for 50 and 7.00 for the o rings.
its not worth it! The entire return line kit is 26.00 shipped.
Old Aug 29, 2011 | 10:12 AM
eatont9999's Avatar
eatont9999
It is when you have swapped out your injectors as many times as I have. HAHA.
Can you post a link to the washers? I spent an hour on their site yesterday and I couldn't come up with the right size.
Old Aug 29, 2011 | 10:31 AM
tecgod13's Avatar
tecgod13
I disagree!! The plastic caps can be reused if you are careful removing them. 50 o-rings is enough to redo the return lines 3 times. Especially worth it if like eaton, you are trying to trouble shoot problem injectors.
johneich
26
Jul 7, 2019 08:46 AM
RickW2007
31
Mar 5, 2017 12:16 PM
ldsparamedic
Oct 21, 2013 12:41 PM
Pigeon
Apr 2, 2008 04:12 PM
crazymike
Mar 20, 2007 03:28 PM
