Sponsored by: Real Truck
A/c
Old Aug 26, 2011 | 03:52 PM
johnt471's Avatar
johnt471
A/c
My a/c will just cut off while I'm driving and then will come back on when it wants to and works fine. Any ideas
Old Aug 26, 2011 | 07:01 PM
BigAlsPSD's Avatar
BigAlsPSD
Is the blower shutting off? Or does it just stop getting cold? If it's just stopping getting cold check the air gap for the clutch, easy check cheap fix.
SpringerPop's Compressor Clutch Air Gap
Old Aug 26, 2011 | 07:05 PM
johnt471's Avatar
johnt471
Just getting cool.how do you check the air gap
Old Aug 26, 2011 | 07:07 PM
BigAlsPSD's Avatar
BigAlsPSD
Check the link in my post, easy check is if its idling and not getting cool tap the clutch and see if it engages, if so it's likely your gap.
Old Aug 26, 2011 | 07:11 PM
johnt471's Avatar
johnt471
Oh ok I dident see it. I'm on my phone. Thanks
Old Aug 26, 2011 | 08:39 PM
johnt471's Avatar
johnt471
Do you know of that will work on mine. I have a 5.4 and the compressor is on the bottom by the block. And it was talking about being for a diesel. Should ne the same for all right.
Old Aug 26, 2011 | 09:50 PM
BigAlsPSD's Avatar
BigAlsPSD
Same concept for the compressor clutch I would think.
Old Aug 26, 2011 | 10:49 PM
johnt471's Avatar
johnt471
Yea I just checked it and thats it. Thanks alot Big Al.
Old Aug 27, 2011 | 11:32 AM
mountie's Avatar
mountie
Wish I was that lucky. My Excursion has a rear hose leak and Ford wants $933. to replace it and recharge the system.
Old Aug 27, 2011 | 12:08 PM
johnt471's Avatar
johnt471
I don't know how hard that would be to change. But at 933$ I would try it my self first. But hey I'm cheap so....
Old Aug 27, 2011 | 04:20 PM
BigAlsPSD's Avatar
BigAlsPSD
Great, we all like cheap fixes
Old Aug 27, 2011 | 06:45 PM
HomerWinzlow's Avatar
HomerWinzlow
Well if that pipe goes from the front to the rear, you sure arent going to get it done on the driveway. You might be able to cut out the old one but the new one cant be cut back in..
If you can pull the body off you can get to them real easy!
bitsy
Jun 10, 2015 11:02 AM
chris86924
Aug 14, 2011 06:28 PM
twg1966
Apr 27, 2011 09:54 PM
Swingshiftworker
Aug 29, 2009 08:53 PM
novalovr66
Jun 6, 2008 01:16 PM
