Intermittent A/C!
Old Jun 6, 2008 | 09:04 AM
novalovr66's Avatar
novalovr66
Exclamation Intermittent A/C!
I have a problem that has been bugging me. I own a 01 Ford F350 DRW with a 7.3 PSD. The problem is, when its really warm outside the A/C will initially work ok, blows cold air for a little while then starts blowing warm air. I give the truck gas (high RPM), and i can hear a clunk, which i assume is the compressor kicking back in, then more cold air for a couple of minutes or so, then it starts blowing warm air again. Every time it starts blowing warm air i give it gas (high RPM) I can hear the clutch kick in and more cold air. I assume the clutch is going bad. Is there anything else it could be? Thanks for your help in advance!
Old Jun 6, 2008 | 09:11 AM
rbaker6336's Avatar
rbaker6336
check the air gap on you A/C clutch,sounds like you may need to remove a shim
Old Jun 6, 2008 | 09:13 AM
novalovr66's Avatar
novalovr66
BTW, the truck has 122,000 miles on it and has never had the A/C clutch or compressor replaced/repaired. What should the air gap be and how do i check it?
Old Jun 6, 2008 | 09:20 AM
rbaker6336's Avatar
rbaker6336
Measure air gap between A/C clutch and A/C clutch
pulley mating surfaces at three equally spaced locations with a feeler gauge. Record the measurements.
If each of the three measurements taken is not within 0.35-0.85 mm (0.014-0.033 inch) , remove the A/C clutch.
Remove and measure the A/C clutch hub spacer. Select the appropriate thickness A/C clutch hub spacer to place the air gap within specified limits.
Install A/C clutch hub spacer and A/C clutch. Recheck air gap measurement.
Old Jun 6, 2008 | 01:04 PM
SpringerPop's Avatar
SpringerPop
Classic air gap.
Reading these would be a good place to start:
https://www.ford-trucks.com/forums/6...-question.html
and
https://www.ford-trucks.com/forums/5...ml#post4464164
Pop
Old Jun 6, 2008 | 01:16 PM
UP_There's Avatar
UP_There
check the gap like they said above.......also, I had a problem with the wiring in the plug. It had worn out and didni't have a good connection. Fixed the wiring, and works like a champ
Pitcrw6
May 1, 2025 08:07 AM
lowrider50
2004 - 2008 F150
Jul 9, 2014 07:47 AM
jeffrey5679
May 8, 2013 09:29 AM
rpbfixit
Jul 30, 2012 11:20 AM
raineytx
Aug 8, 2005 10:10 PM
