Sponsored by: Real Truck
Fuel gage doesnt work.
Old Aug 25, 2011 | 11:22 AM
Ridenred333's Avatar
Ridenred333
04' v10 cc f250 fuel gage stop working.. Ran it low to top of red just above E. Parked truck for about 5 days then put 7 gals in it. Gage didnt move i figured that it would move to just below 1/4.. but anyways so i added 5 gals more still wont move even up to the E.. Any ideas. Is the part that could be bad the fuel sending unit. I though it was called a float but couldnt find the part on rock auto..
Old Aug 25, 2011 | 12:12 PM
Pili's Avatar
Pili
Its part of the sending unit. Only two things can cause the gauge to stop working. The sending unit or a bad ground. Depending on how many miles you got you might as well replace the pump while your at it.
Old Aug 25, 2011 | 04:26 PM
willie00's Avatar
willie00
Trailering
Check the wiring to the sending unit. It runs in a bundle of wires on the left inner fender and down the left frame rail. Same thing happened to mine a few months ago. Found that some type of rodent had chewed the wire in two places. If yours has sat for a while that could be a likely cause.
Old Aug 25, 2011 | 05:22 PM
Rongold's Avatar
Rongold
FUEL GAUGE INOP
Try banging the bottom of the tank with a rubber hammer--float could be stuck.
RON
Old Aug 25, 2011 | 08:14 PM
Ridenred333
Well I will start with the easiest, banging the tank.. Then checking wires, then if those dont work I will have to replace sending unit.. I am a poor low ranking soldier in the army.. So I think I will have to wait on replacing the pump..
Old Aug 25, 2011 | 09:22 PM
Desert 4x4's Avatar
Desert 4x4
You will need to drop the tank, I just went through this on my truck. There is one wire on the sending unit that broke at the solder joint. I would try to resolder the wire. I replaced the sending unit because I purchased it before I dropped the tank. If I had known about the single wire it would of saved me $200 at the dealer. Hope this helps
Old Aug 25, 2011 | 10:18 PM
Rongold's Avatar
Rongold
IN TANK GAUGE
The fuel level sender is available separately at Rock Auto. It is listed under "Fuel Tank Sending Unit" under the fuel/air heading.
RON
Old Aug 25, 2011 | 10:24 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
mine sticks somtimes...except it sticks at full or will show full out of nowhere when its not full. once i fill it up again though, all the way i have no issues. very intermittent problem for me.
Gunnie357
Jan 23, 2019 10:28 AM
p36uranium
May 15, 2011 07:19 PM
Aaron-71
Aug 19, 2010 05:41 PM
shameless
Apr 9, 2009 11:46 PM
sailboat2323
Electrical Systems/Wiring
Aug 29, 2004 04:43 PM
