help id this door? part
Old Aug 25, 2011 | 07:09 AM
r_reed's Avatar
r_reed
i had this in my jar of door handle, latch, etc. parts. i don't remember where it came from. does anyone recognize them? thanks, dick r.
Old Aug 25, 2011 | 07:32 AM
Doc's Avatar
Doc
Those are grommets that are in the firewall for bolts/nuts. For the life of me, I can't remember what exactly they help hold, but they belong on the firewall.
Old Aug 25, 2011 | 08:25 AM
56panelford's Avatar
56panelford
I was thinking it went on the end of the arm from a window crank and slides in that thingy a bob(track) at the bottom of the glass. Will there be a prize at the end of this contest,lol
Old Aug 25, 2011 | 09:44 AM
r_reed's Avatar
r_reed
i'm leaning toward the firewall grommets which i did around the same time. the firewall padding went around them and now i rem taking the padding and the grommets out. must have stuck them in the door hardware jar. the prize may be grommets themselves since i don't plan to put them back. thanks for helping me with the puzzler. dick r.
Old Aug 25, 2011 | 10:09 AM
51PanelMan's Avatar
51PanelMan
Is it threaded? If I'm not mistaken, that's one of the "cup" nuts or washer that holds the pedal-to-carb linkage through the firewall. There should be two of them.
Old Aug 25, 2011 | 12:00 PM
mtflat's Avatar
mtflat
Ilya is right, but it's not threaded. Inside the cab - bolt from the accel pedal cross shaft goes thru the firewall, into the cup. Nut inside the cup secures the assembly to the firewall. The depth of the cup is to accomodate the firewall padding.
Old Aug 25, 2011 | 12:05 PM
51PanelMan's Avatar
51PanelMan
DING, DING, DING, DING!!!!! WINNAH, WINNAH, WINNAH!!!!
That's exactly what I pictured in my mind, but you explained it in words.
So, what do I win?
Old Aug 25, 2011 | 12:26 PM
56panelford
Dang, I'm still on my loosing streak,lol
Old Aug 25, 2011 | 01:16 PM
r_reed's Avatar
r_reed
thanks to all. you jogged my memory. when i took the nuts off those cups the throttle linkage about fell off the other side of the firewall. i put the nuts back without the cup, whatever. don't intend to put them back so 51 panelman, if you would like to claim them for your prize, email me your snail mail and i'll send them off to you. congratulations. dick r
Old Aug 27, 2011 | 07:51 PM
FortyNiner's Avatar
FortyNiner
So, when I was working on my '49 earlier today, I noticed exactly two of these holding the firewall insulation. They straddle the tranny floor plate and don't have any relationship to the linkage.
Always listen to Doc.
Old Aug 27, 2011 | 08:07 PM
r_reed's Avatar
r_reed
that's what i figured until i looked under the hood and saw the cross shaft falling off the firewall. put the bolts back in without the cups.
Old Aug 27, 2011 | 08:10 PM
FortyNiner's Avatar
FortyNiner
So now I learned something - thanks!
Old Aug 27, 2011 | 08:11 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle
Name that part!
Awe man! I missed out on the fun! And there should be a gameshow based on this!
1984_6.9
17
Aug 1, 2016 12:00 PM
deyomatic
Oct 27, 2008 06:42 PM
tomtank77
1983 - 2012 Ranger & B-Series
18
Jul 16, 2006 03:08 AM
