1978 F250 Custom Interior
#136
#137
Search Results for autometer z series - SummitRacing.com
#140
Thanks. I did this a couple years ago. This was my first attempt at doing this sort of stuff. Wasnt really to serious about it, realized I was actually pretty good at it and did a ton of research, got all the tools I needed and started it all over again the beginning of this year. Its all in my other "Redone" thread if you havent seen it.
#142
Window switches are down right below the middle seat in the console.
#143
Parts list info
Man this interior is slick and you've given me insight on how is like mine to look. I'm currently trying to door my door panels and wasn't going to go as far as fiberglass ing the whole door to make full panels( which I'd love to do) but it's not in my truck budget.
What I was trying to figure out is the door handle placement. Did you have to cut out the metal part of the door to recess it?
What type and size foam did you use under you material?
How did you get the pattern or lines in your design? Did you have to see those that way the then tuck them or did you piece them together separately in layers ?
Dude thank you for the insight this is the best detail I've seen any design. Thanks
#144
Wicked Endings
23
04-11-2010 11:58 AM
