351m-400 starter replacement.
Old Aug 24, 2011 | 07:02 PM
crsmiffy's Avatar
crsmiffy
I tried this in the engine forum, but CTUBUTISA suggested i try this one. Gentlemen, I am in the market (soon as money allows) to replace the starter on my 400-C6. It is the old rat trap type and on a bit of a strip down when the engine was reguilt it is seriously on the way out. The armature and brushes are both well worn and I believe it is the original from back in 72. I will be fitting headers as the OEM cast log units have been cracked/repaired before and are on their way out.
So between the worn starter (still starts ok for now!!) and the clearance I need to get the headers through I would like a smaller one so a gear reduction one would be the go.
My problem is I don't have a lot of money to play with (who does) so the obviously good ones like CVR at $300 plus are a toughy to swallow. They have them here in Australia as well as a local who makes a very similiar unit i.e. indexable, small and gear reduction as well as the price albeit a tiny bit cheaper. There seems to be a very limited market for the 400's in the cheaper starters. Bucketloads for the Chev's and Windsors but the clevelands and 429/460's are very few and far between. The wreckers over here are no good either. We just don't have the massive amount of F-trucks over here to rob an applicable starter off and I have been told they just don't have them.
I have been looking on evil bay and there is an outfit called Alterstart (Texas?) that do a cheaper alternative approx $130US. for around $40 to get it here to Aussie, a $180 starter would be not to bad. Warranty would be problematic so thats the reason for this post. Alterstart any good, or are there any other alternatives? Cheers.
Old Aug 24, 2011 | 09:49 PM
wyckedcombo17's Avatar
wyckedcombo17
When I put starters on cars, I usually go with Bosch. To me, it's like an el cheapo 1/2" drive. It'll work, but when you really need it, its gonna break. I would say go with the cheap one if you can warranty it, but that's an issue. You'll probably end up paying more in the long run with the cheap one, but I have no experience with Alterstart. Hopefully someone else will chime in.
EDIT: Quick search on google noted generally positive reviews on rebuilt starters.
Old Aug 24, 2011 | 10:30 PM
crsmiffy's Avatar
crsmiffy
Thank you. That was quick! I'll see what else pops up.
Old Sep 7, 2011 | 12:48 AM
crsmiffy's Avatar
crsmiffy
Thats It? No olse has had ANY experience with starters?
gray035
20
Nov 8, 2016 01:26 AM
BruteFord
28
Aug 20, 2014 12:33 PM
crsmiffy
Aug 15, 2011 10:48 PM
1977 Explorer
Nov 4, 2009 09:41 PM
gskershner
Feb 26, 2007 02:23 PM
