Sway bar link torque
Old Aug 23, 2011 | 06:59 PM
youngrg's Avatar
youngrg
Does anyone have the tourque specs for the sway bar links on a 1999 Explorer Limited? ... Thanks... Ron
Old Aug 23, 2011 | 09:18 PM
shorod's Avatar
shorod
The OEM style end links are a long bolt that goes through the bushings at the bar as well as the bushings at the control arm and the nut is on the underside of the control arm. The nut should be torqued to 21-29 Nm or 15-21 lb/ft per the factory service manual.
-Rod
Old Aug 23, 2011 | 10:14 PM
aquanaut20's Avatar
aquanaut20
The torsion bar is preloaded at ride height spec, not torque, the lock nut is torqued to +/-20'#.. Philip
Old Aug 24, 2011 | 06:33 AM
shorod's Avatar
shorod
You pulled a me. He's asking about sway bar end links, not torsion bars.
-Rod
Old Aug 25, 2011 | 06:12 PM
aquanaut20's Avatar
aquanaut20
Sorry Rod,
That's what happens when you read posts on a smartphone with no reading glasses.... LOL... Philip
Andrew010
6.7L Power Stroke Diesel
43
Oct 31, 2014 08:16 PM
Jessef250
Dec 4, 2011 04:34 PM
DAVE67FD
Mar 23, 2009 01:50 PM
Forty9ford
1997 - 2003 F150
May 26, 2005 07:53 PM
