I need some help
Old Jul 7, 2001 | 04:00 PM
1ole4d's Avatar
1ole4d
I need some help
on a 1978 F-150 4wd. i'm trying to remove the dashtrim to replace the speedometer cable but I cannot remove the **** for the headlight switch or the wipers. Anyone know how to remove them? The book says something about a little button you push in but I don't see on on either ****.... Any ideas??
Old Jul 7, 2001 | 04:30 PM
whomrig's Avatar
whomrig
I need some help
The little button is behind the dash, on the top or bottom of the headlight switch. Pull the fuse for the headlights, reach up behind the dash, find the button, push down, pull out the headlight ****. Not sure if the wiper switch is the same or not.
Wayne 60 F-350
e-mail
https://www.ford-trucks.com/users/whomrig
Old Jul 7, 2001 | 05:06 PM
1ole4d's Avatar
1ole4d
I need some help
Ok...got that done. Thanks Whomrig. Now if I can just figure the wiper **** out I'll be all set. Thanks again....time to get back to work. Later
Old Jul 7, 2001 | 07:08 PM
71swissaqua's Avatar
71swissaqua
I need some help
THE WIPER SWITCH ON MY 71 HAS A SMALL ALLEN SET SCREW ON THE BASE OF THE ****. cOULD BE THE SAME AS YOURS. HOPE THIS HELPS.
Old Jul 7, 2001 | 07:54 PM
MEPHISTO_XES's Avatar
MEPHISTO_XES
I need some help
The wiper **** just pulls off,man. Theres a clip inside the **** that holds it on.
Old Jul 7, 2001 | 09:41 PM
wilks80's Avatar
wilks80
I need some help
