Modular V10 (6.8l)
MPG DOESN'T ADD UP
Old Aug 23, 2011 | 07:53 AM
VONxRUBENxLA's Avatar
VONxRUBENxLA
MPG DOESN'T ADD UP
Ok so I have a 02 250 SD short box crew cab and my trip computer is telling me I only get 233 miles till empty right after a fill up which with a 29 gallon tank thats 8.03 MPG. I drive about 75-25 streets vs Highway and dont drive it hard.
Why are soo many getting over 10MPG?? Someone told me they get atleast 300 miles a tank. What am I doing wrong?? Or can the trip computer be wrong?
Old Aug 23, 2011 | 07:54 AM
VONxRUBENxLA
There is just a leveling kit on it with 305/75/16
Old Aug 23, 2011 | 08:11 AM
hunt1moore's Avatar
hunt1moore
After reading a post on another thread here, I'm going to check my MPG next time using a GPS to determine my milage vs the odometer reading. With the larger tires you my want to do the same to get an accurate calculation.
Old Aug 23, 2011 | 08:26 AM
VONxRUBENxLA
would it mess it up if i ran the tank empty to see how many MPG i get? i was thinking of next time the gas light comes on fill up my 5 gallon container and be prepaired
Old Aug 23, 2011 | 09:16 AM
hunt1moore's Avatar
hunt1moore
Your stock tire size was probably 265/75/R16 (30") or smaller.
Current tire size 305/75/R16 (34")
Your odometer (if it has not already been re-calculated for 34" tires) would read fewer miles with a set of 305/75/ R16 tires.
A gps will give you a more accurate milage number from point "A" to point "B" to divide the gallons consumed into. Effectively your mpg should go up.
I don't see much advantage in running your tank "empty" to check your mpg. Consuming 3/4 take should be good enough.
Old Aug 23, 2011 | 09:55 AM
VONxRUBENxLA
oh so not only should the speedo be recalculated by the odometer needs to be done as well? my speedo reads right checked that with a speedo app on the iphone lol
Old Aug 23, 2011 | 10:17 AM
hunt1moore's Avatar
hunt1moore
Then your gas milage sucks! lol!
Old Aug 23, 2011 | 10:19 AM
VONxRUBENxLA
Thanks hahaha.
Old Aug 23, 2011 | 10:45 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
Some things to think about; You probably have 3.73 gears and the stock tires for a F250 were 235/85/16 so having 305 tires your finale gear ratio is way to high causing your truck to work harder burning more fuel.
When I was still in business one of the general contractors I worked with had a F250 SC V10 with 3.73 gears and running with a light load would never get the mileage I was getting with my F350 CC with utility box, 4.30 gears loaded to almost max GVW 24/7. I always got 9.5 to 11 in the summer (winter I let it run to keep warm) depending if I was pulling one of my trailers. Changing the final gear ratio always changes something else good or bad in your case bad.
Denny
Old Aug 23, 2011 | 01:47 PM
BigPigDaddy's Avatar
BigPigDaddy
Originally Posted by rvpuller
You probably have 3.73 gears and the stock tires for a F250 were 235/85/16 so having 305 tires your final gear ratio is way to high causing your truck to work harder burning more fuel.
Exactly. Bigger tires = more throttle to get her rolling in traffic. City driving MPG will suck accordingly.
Old Aug 23, 2011 | 05:35 PM
Sebs's Avatar
Sebs
First of all I wouldn't use a computer prediction of how many miles I might get out of a tank to calculate my mileage. I would do it the way we used to do it before computers. Fill up and set your trip meter. Next time you fill up divide the trip meter miles by the number of gallons you put in at that fillup to get your miles per gallon. Of course if your odometer is not accurate because of tire size you won't get a good number. Use your GPS to figure how far it's off and factor that into the calculation.
Old Aug 23, 2011 | 06:18 PM
BareBones's Avatar
BareBones
Also, if you want to check the accuracy of your speedometer directly, just clock the elapsed time between mile markers on a stretch of interstate. It will take exactly 60 seconds if you hold 60 mph.
Old Aug 23, 2011 | 08:38 PM
Quad Racer's Avatar
Quad Racer
I would definately not run the truck out of fuel. Ive been trying to work on mileage lately myself. Just use the trucks computer to help and not rely on it solely. I use it as a challenge to see what kind of numbers I get and in doing that I find myself driving like a grandpa and feel guilty when I have to use all the motor. Im constantly looking down at it and it helps atleast to save fuel whether its accurate or not. Do it by hand and itll be better. Keep her tuned up and its all you can do.
Old Aug 24, 2011 | 09:28 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
I don't know if it was mentioned, but the 29 gallon tank, when the low fuel light comes on, usually only takes 24 gallons, at least it does for me.
The best way to check MPGs is record the miles, fill the tank, drive until it's low enough you care, and then fill again. Divide miles by how many gallons to fill.
It would be best if you use the same gas station, same pump, but not entirely necessary.
And, of course, like already said, check your actual miles with a GPS versus the odometer.
Old Aug 24, 2011 | 10:10 AM
Ebroten's Avatar
Ebroten
Also make sure you fill up the same way too. I know my tank will take an extra 2.5 gallons from the first time the pump automaticly shuts off. I just have to pump the rest at half speed.
