I've had mine on my truck for about 18 months, but there are others on the site who had run them longer, maybe a few years.
My exposure with the Leece-Neville goes back 3 decades. We had to run test programs with many different fleets, OTR, transit, emergency services, commercial, mining, etc and Pestolite units were always around. High output, long hour demand situations. While every brand has problem child's, the service personnel I talked with were complimentary about the brand. What I like about this unit is the engineering thought that went into it.
It a twin fan setup to make sure there is good airflow through the unit. I've shot my IR on the unit after an hour of running and it's not hotter then anything else under the hood. But if you running stock and going down the road in daytime your only demanding 25-30a. The other design factor is that the diodes are welded in place rather then soldered, so they are manufacturing for a commercial high temp environment rather then ease of manufacturing.
Thanks Jack your experience and opinion is appreciated
and from your info it sounds as though they have addressed the Heat issue what is likely the most common cause for degradation and ultimately unit Failure
in the same boat as you blade mine started lighting up a cpl months ago and voltage is dropping gotta buy me an alt soon and get it changed
Is you Battery light on
Mine is Not
Iv cleaned cables but Iv got to do a Couple more I don't suspect it will help but to be thuro it got to be done
But I can see voltage go down as the heat of the engine coming to temp and seems to drop lower as the heat of the day comes day on also maybe its in my imagination some but Iv watched numbers for along time on this rruck Thru multiple alternators now so my gut says its dying
even the startup volts is lower with longer to recover the initial GP cycle drain
Benny, how low is it going and where is the reading from?
Most modern alternators are built with temperature compensating regulators so the batteries are not overcharged in hot weather and boil off. You've had experience with this unit so I'm not doubting your observations, but I wonder if you got a combination of temp and harness ground resistance that may be at fault.
Lower startup voltage at these temps is not a good sign, but with these temps the batteries resistance is low so they accept more current then cooler weather, so it will take longer for the voltage to climb back up. Again, your truck, your observations over time are a credible source. Not trying to butt heads.
.... and from your info it sounds as though they have addressed the Heat issue what is likely the most common cause for degradation and ultimately unit Failure
I look as these units as a Mack truck solution. They are designed and built for true commercial use. Mine came off the shelf as I said from a situation where the units ware being installed on Ambulance and Emergency Services units. While not from NYC, I've been to NYC fleet operations and the local Ford FSE that I also know services NYC. Those units he claims are basically never shut down and run with heavy electrical draw. I know NYC ate a lot of FICMs when they ran the 6.0L, and their equipment got upgraded I believe to these too. I'll have to ask him when I see him next.
it struggles to make it into the 12volt range during the GP cycle its at 11.6-12.2 until GP kick off
Used to about bounce to 12+ immediately and be at 12.6+ at the end of GP cycle
then it will bounce to 13.6-13.8 range maybe a glimpse at 14.0 for a few during first 10 minutes or so
then steadily hangs around 13.2-13.4 after that with the occasional glimpse of 12.8 the 12.8 is very very brief and is back up to 13.2+ on the next SG update cycle so gauge reports that (12.8volt) for 3 seconds or so
I noticed this Last summer just not as low of voltage drop
For the sake of Trying to being thuro and buying something I don't need I will clean grounds off the battery and hydro test the batterys tomorrow
I had No Idea these alternators regulate for heat Makes perfect sense but its also complicates it to a degree you guys know what I mean
my light sometimes will come on then will go off shortly. watch the sg, when it started I wasn't concerned but over the course of weeks it only hits as high as 13.2 now and spends most of its time below that.
