Battery light flickering / intermittent
Old Apr 2, 2019 | 11:42 AM
MD_7.three's Avatar
MD_7.three
Noticed the past two mornings my battery light was flickering on and off intermittently....and occasionally on my powerport usb charger I'd see the voltage drop from its normal steadystate 14.2 down to as low as 13.4...
Is it time for a new alt already? I have records that show a new one was put on about 10 months before I bought it (so about 3 years and 30k ago) seems awfully soon no? Batteries are of the same vintage which would seem more likely to be time to replace but they have started great all winter and sit at a healthy 12.6v every morning when I get out to the truck...
Old Apr 2, 2019 | 12:42 PM
SRBF150's Avatar
SRBF150
From my experience, yes, it is time for a new alternator. I've had good luck with lifetime since adding a ground cable from one of the alternator mounting bolts to the chassis as a side note.
Old Apr 2, 2019 | 01:20 PM
Colorado350's Avatar
Colorado350
Test everything. Remove batteries, charge individually then get load tested. Pull alternator and have it tested, then proceed with the actual fix.
Old Apr 2, 2019 | 02:51 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Test both the alternator and load test batteries like Colorado said. 3 years is a long time.
Old Apr 2, 2019 | 03:13 PM
sunuvabug's Avatar
sunuvabug
Hey MD, sounds like the issue I had. Before removing the alternator, have them test it to see what it is putting out. If the problem was like mine, it was the regulator wire that was shorting. Click on the "Bad Regulator Wire" link in my signature for my story. Good Luck and let us know how your story ends.
Old Apr 2, 2019 | 03:14 PM
MD_7.three's Avatar
MD_7.three
I just got home and engine off I get 12.58v across each battery. Engine running I’m reading 14.24v across the alt...
its hit hit or miss intermittent. Think I read another thread about one of the diodes going bad in the alternator ... that or a short somewhere causing the voltage to sink intermittently. I can’t seem to recreate it. Sometimes it’s done it cold, sometimes on a warm engine. Sometimes while it idles, sometimes under WOT, and sometimes not...
i dont have time to screw around or lose a day at work so I guess I’ll start with the alternator and go from there...
Old Apr 2, 2019 | 03:16 PM
MD_7.three's Avatar
MD_7.three
i will definitely read up and check this out...thanks!
Old Apr 2, 2019 | 03:29 PM
Colorado350
If you replace the alternator and the batteries are bad it can stress/kill the new alternator to failure. If you replace the batteries and the alternator is bad you can stress/kill the new batteries. Neither of those options are cheap, my point test both the alternator and the batteries it doesn’t take all day and can potentially save you a chunk of your hard earned money.
Old Apr 8, 2019 | 10:01 AM
MD_7.three's Avatar
MD_7.three
Just to wrap this up (hopefully) I took it by Autozone and had them test the batteries and the alternator...both tested fine, but I could not duplicate the flickering battery light while there...they suggested bringing it back with the light on
After a couple days I noticed my Batt voltage in the morning was dwindling...so I decided to just go for it and replace the alternator with the bigger 6.0 one...
Bought it from DB Electrical on Amazon (new, no core charge, and under $100) and saved a boat load even over the autozone reman priced "lifetime" units and that's before they wanted $45 for a 6.0 style core which I didn't have...
Installed Saturday and so far so good, batteries back up to 12.7 this morning after a couple longer drives this weekend, and running voltage 14.3-14.5 with no battery light flicker.
Old Apr 8, 2019 | 10:07 AM
sunuvabug's Avatar
sunuvabug
Hopefully the new alternator will solve your problem. Thanks for closing the loop Josh.
KHflatbed
May 31, 2017 10:18 AM
92will
Jul 14, 2015 04:54 AM
adammdennis11
Nov 25, 2013 07:07 AM
gofast51004
Feb 21, 2009 03:51 AM
bkuuz1
Sep 12, 2008 12:19 PM
