rear spring perch rustout
Old Aug 22, 2011 | 05:58 AM
miottimouse's Avatar
miottimouse
i am wrecking out a 79 f100 for the engine/trans and my brother in law is going to use the frame for a body swap as his got hit i noticed the rear perches are almost totaly rusted out below the spring is this a common thing? as i have never seen that before in all the time i have had these trucks he will have to grind/punch out the rivits and reuse his for sure makes me wonder why a drain hole was not drilled out but i think that would help
Old Aug 22, 2011 | 08:57 AM
mark a.'s Avatar
mark a.
After reading I'm not sure what is rusted out ? The spring perches are the thick steel pads that are welded to the axles tube & the springs get bolted to them with U bolts. I'm thinking you mean the rear spring hanger ? If so it is very common for them to rust out, especially the north.
Old Aug 22, 2011 | 11:33 PM
miottimouse
yes thats right the hanger sorry couldnt think of the proper name at 3 in the morn but thats what needs replaceing
Old Aug 23, 2011 | 02:31 PM
ChaseTruck754's Avatar
ChaseTruck754
I've got rust free, calif. spring hangers sitting here for sale if your brother will be using this truck and needs them. I used to scrap body mount towers, spring hangers, etc. when parting these trucks but after having a bunch of guys on here asking for them I've been taking the time to keep them now.
Old Aug 23, 2011 | 09:42 PM
Goliath1975's Avatar
Goliath1975
I had a rotted out spring hangar on my highboy and I couldn't see using 35 year old mounts so I fabricated a new one out of 1/4" plate and some notched out square stock. I'll try to get some pictures up if anyone cares. Oh, we torched out the rivets, but I'd say a grinder would do the job just as well.
Old Aug 24, 2011 | 05:33 AM
miottimouse
sounds good i will keep that in mind every thing on his frame can be used as the whole truck only has 30,000 original miles even the doors have that "new car close sound"
Old Jan 8, 2013 | 05:37 PM
Sylver's Avatar
Sylver
never mind
Old Jan 8, 2013 | 05:42 PM
lafermedavid's Avatar
lafermedavid
hangers
Hey chase you wouldnt happen to have rear front hangers for highboys would you?dave
Old Jan 8, 2013 | 05:49 PM
ChaseTruck754
Nope - sorry. Sold um to a guy on here already.
Got the leafs, shackles, blocks, crossmember & some other parts off the back end still but the hangers sold.
Old Jan 8, 2013 | 06:16 PM
lafermedavid
thanks
but the hangers sold. yep
jbarefoot
Mar 14, 2011 09:15 AM
hillbillyford
1983 - 2012 Ranger & B-Series
Aug 3, 2010 03:19 PM
someday
Jun 10, 2008 12:59 AM
RussB
27
Apr 18, 2008 08:23 PM
