Big weekend, and still have problem
Old Aug 21, 2011 | 08:07 PM
yooper_72's Avatar
yooper_72
Ok well it was a big weekend, and still have problems. I have a 78 150, with a 300 L6, NP 435, NP205.
Was leaking oil from the weep hole in the bell housing, and the transfer case. Not a problem got a reseal kit for the 205, what the hell also got one for the 435 and a new rear main also a new clutch since I was in there. Don’t forget a couple cases of beer also. Two days to take everything apart reseal and fix some minor things that I found along the way and put together. Got everything together, ran it for about an hour, adjusted the clutch, not any problems. Drove eight miles home and parked, 30 minutes later a new spot in the drive way, crawled under and leaking from the weep hole aging, any idea what’s going on, or a fix for it?
Thanks for the help
Old Aug 21, 2011 | 08:20 PM
supercabfreak's Avatar
supercabfreak
well i gues you need to clean it up and figure out what its comeing from ....tranny or engine
Old Aug 22, 2011 | 12:51 PM
bigdaddys76's Avatar
bigdaddys76
Motor oil? if so then your crank shaft bearings are worn the ceank is dropped down and is egg shaping your rear main seal and will continue to leak no matter how many times you replace it.
NVpowerstroke
Apr 5, 2019 09:00 PM
vroom9
Jan 17, 2017 07:11 PM
thatranger
May 17, 2013 11:32 AM
LittleRedRanger4.0
Dec 14, 2012 09:55 AM
4x4 Bart
Aug 21, 2008 07:54 PM
