dash pad paint?
Old Aug 19, 2011 | 09:04 PM
shorty2tall's Avatar
shorty2tall
dash pad paint?
ok so my dash is cracked like most but got one that is brown and not cracked and original is there paint to paint them? and what should i use to clean it and keep it soft and not cracking?
Old Aug 19, 2011 | 10:38 PM
HIO Silver's Avatar
HIO Silver
Clean it with a mild solution of soap and water. Use a folding windshield screen whenever yer parked to keep the cab cool and sun (and UV rays) off of the dashpad.
NEVER USE ARMOR ALL OR OTHER "PROTECTANT" UNLESS YOU INTEND TO KEEP DOING IT UNTIL THE LAST DAY YOU OWN THE RIG OR SUBSEQUENTLY DIE.
That greasy crap makes the surfaces look good. But it artifically saturates the vinyl and "outgasses" as it dries. The evaporated protectant will leave a film on all of the windows that is a pain in the azz to remove. If you ever stop using it, the dash will dry out and crack. My 65 'Stang has been in my family since 1979. I bought it off my brother in 2005 and he's an all-show kinda guy and he used Armor All on everything...now I have shrunken and cracked upholstery, a cracked dash, a slimy film on the glass, and fisheyes when I tried to touch up the doors with a little paint.
Old Aug 19, 2011 | 11:02 PM
shorty2tall
is there a paint that is safe on them?
Old Aug 19, 2011 | 11:11 PM
devino246's Avatar
devino246
LMC and pretty much any parts store sells a spray on dye type stuff made for plastics and vinyl.
Old Aug 19, 2011 | 11:55 PM
shorty2tall
ok thank u sir!!!
Old Aug 20, 2011 | 08:44 AM
shookdaddy's Avatar
shookdaddy
I did the new dash pad n mine about 5 yrs ago n I used the duplicolor vynal n fabric paint from walmart I works really good just clean it up w a acetone cleaner to get any oils off then put down a adhesion promoter then spray ur color the only problem I've ever had is on my door panels were I rest my arm over time it wears of but I clean It and touch it up n it blends rite in w the old paint
Old Aug 20, 2011 | 05:15 PM
coolcoupe's Avatar
coolcoupe
dash pad
Someone told to rub baby oil on it. Is this a no-no or a good idea?
Old Aug 20, 2011 | 11:38 PM
redneckcustoms13's Avatar
redneckcustoms13
Sem fabric and vinyl dye from any reputable auto paint supply is the ticket. They actually have factory color matches and its only $8 a can at my local paint supply.
Old Aug 20, 2011 | 11:50 PM
shorty2tall
would napa have it?
Old Aug 21, 2011 | 08:47 PM
yooper_72's Avatar
yooper_72
Color Bond is what i used on mine, also applied UV top coat, three years in the NM sun and still looking good.
hope you find something you like
Old Aug 21, 2011 | 09:46 PM
kobaltblue's Avatar
kobaltblue
Dupla color (From the parts store) satin black works great.
Old Aug 22, 2011 | 01:56 PM
redneckcustoms13
napa may carry sem. ive seen good luck with the duplicolor also
DesertStorm
Paint & Bodywork
Jan 2, 2008 11:11 PM
cujo8
Appearance & Dress-Up
Jun 24, 2006 06:37 PM
FF27
May 26, 2004 10:12 PM
Dustin_86
Paint & Bodywork
Jan 2, 2004 06:03 AM
dbarracuda
May 26, 2003 08:33 PM
