Leaking Injector(s)?
Old Aug 21, 2011 | 06:28 PM
gmcbride's Avatar
gmcbride
First, I apologize if this has been covered before. I did a search and came up with several thousand responses, so either this is a real problem or my search capabilities are no better than my mechanical skills. So, to the problem. I just changed my oil, 88,000 (6,000 on the oil) and sent off a sample to Blackstone. It came back with 2% fuel content which is literally twice the normal amount. They indicated i should be very concerned that one or more of the injectors maybe leaking. I did a coolant flush during this cycle and let it idle quite a bit while doing so. Is there a way to check the injectors without tearing the top of the motor apart? Thanks, gm.
PS-The motor runs great!
Old Aug 21, 2011 | 10:53 PM
BLADE35's Avatar
BLADE35
I was getting diesel in my oil at the rate of 1 qt every two weeks I didnt test anything beccause I didnt know how to but I rering all injectors and problem solved
but to test I think you need to do an injector leak down test Im not shure but think you put a gauge on the fuel pressure test port and see if it will hold pressure for awhile as it sits
I wouldnt put off to long as the injector/s that are leaking may become damaged from low fuel pressure
Old Aug 21, 2011 | 11:40 PM
bismic's Avatar
bismic
Personally, I don't think 2% fuel dilution is that bad. I don't mind being corrected if I am wrong, but a certain amount is inevitable.
Also, I wouldn't exactly trust the Blackstone fuel dilution analysis. They estimate it from the flash point analysis. Polaris does it by GC analysis.
Old Aug 22, 2011 | 11:04 AM
gmcbride's Avatar
gmcbride
Thanks, guys. I just changed filters (I know, but I feel better doing every 2K) at 90K and sent off another sample. Hopefully, it is just an anomaly? We'll see. One question, does idling or commuter traffic contribute to this issue? I wouldn't really think so, but..
Old Aug 23, 2011 | 01:59 AM
matty169's Avatar
matty169
Yes it does.....
Idling WILL increase the amount of fuel in the oil. It is called fuel stacking. Not severe in the 6.0 in the summer but that is why the rpm increase when cold and idling.
Jimmy Cash
Jul 12, 2016 07:42 PM
gbrass
6.4L Power Stroke Diesel
May 11, 2016 02:45 PM
farmert
18
Sep 10, 2012 06:10 AM
Beachbumcook
Jun 21, 2011 04:26 PM
ham-n-swiss
Jun 4, 2010 02:37 PM
