need help
Old Aug 21, 2011 | 10:35 AM
frydaddy70's Avatar
frydaddy70
need help
Having EGR problems. mechanic says its the DPFE solenoid but I swear I dont have one. When hot, idles poorly, and rpm drop out momentarily when at cruising speed. Even went to motorcraftservice.com and couldnt find a vac diagram for my calibration code...its not in their list. its a 93 302. Any suggestions?
Old Aug 21, 2011 | 01:50 PM
rla2005's Avatar
rla2005
You do not have a DPFE sensor. Your truck uses the old style EVP feedback. Both styles of EGR feedback use an EGR Vacuum Regulator (EVR) to modulate the EGR valve. What codes are you getting?
Old Aug 22, 2011 | 06:17 PM
frydaddy70's Avatar
frydaddy70
Hey thanks. I got a 332 insufficient flow. I should also mention that it runs ok but poor mileage with the old egr valve and the vac d/c from it. should also say that I have an old custom exhaust, stock exhaust manifolds, true duels, no cat conv, 1 o2 sensor.
shippen
Dec 12, 2011 09:38 PM
equineconn
1997 - 2003 F150
Nov 13, 2010 05:02 AM
Silentst2000
Aug 1, 2005 04:44 AM
StevePitts
Mar 22, 2004 04:02 PM
Laine
Jan 16, 2003 03:04 PM
