Need some help with a leaky SSHPX
Old Aug 20, 2011 | 04:52 PM
Batgeek's Avatar
Batgeek
Many moons ago I purchased a SS high pressure crossover for then ITP Diesel. It has worked great for many years until last month. It started leaking at the connector on the driver's side and since has steadly been getting worse. After much seaching I have found my original plugs. I need to know two things. What torque should I tighten the plugs to. The other is I don't remember if there is an o-ring on the HPX that may have gone bad and if there is what size is it. Considering the number of o-rings that I replaced on this truck since the ultra low sulfur fuel came out I wouldn't be surprised if that is what it is.
Old Aug 20, 2011 | 05:22 PM
guitarpicr's Avatar
guitarpicr
If I recall there is a o-ring on those- Prlbly just need a new one. Did u try & tighten it a little with a backup wrench? Cant help u on the size
Old Aug 20, 2011 | 05:36 PM
Batgeek's Avatar
Batgeek
I did give it a little tweak with a wrench. It leaked even worse after that.
Old Aug 20, 2011 | 06:56 PM
mueckster's Avatar
mueckster
Bob has them in packs of 4. IIRC, It is a #5 ORB. They are the same ones used for the high pressure oil plugs. Product ID# 8-003 Replacement O-rings for Ford Diesel Engines
Old Aug 20, 2011 | 07:49 PM
Batgeek's Avatar
Batgeek
Thanks, mueckster. I should have thought of that since it went in place of the plugs. I found that out when I took off the HPX. The bad thing is that while I was I removing it I noticed that the leak is coming from the compression part not the boss fitting that's going into the thread that has the o-ring. I'm going to play with it some and see if I can get it to seal better. If that doesn't work it was supposed to have a limited lifetime warranty on it. I'll see if it covers this.
Old Aug 20, 2011 | 07:59 PM
timmyboy76's Avatar
timmyboy76
Had to tighten my hpx at the compression fitting some, to stop the leak too.
buddybar
Modular V8 (4.6L, 5.4L)
Nov 23, 2015 09:29 PM
bob6987
Feb 2, 2014 12:31 PM
Lance_I
Nov 5, 2006 06:33 AM
Drive
1983 - 2012 Ranger & B-Series
Sep 1, 2003 11:27 PM
Jimbare
Jul 21, 2002 01:40 PM
